Old 10-06-2012, 03:18 PM   #51 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Would a significant advancement in timing indicate going into lean burn?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 10-09-2012, 05:35 PM   #52 (permalink)
Excellent thread.
I'm from the uk and have an EK3 saloon / sedan with D15z6 engine.
Was looking for an engine mod like this to up the MPG some
More.
Sorry for my ignorance ,I'm not very technical.
From what I've read is Lean burn safe in stationary & in 1st / 2nd gear as the lean burn temperature is actually lower than standard operating temperature ?
Use of this will depend on how hot the climate is ?
I always assumed lean burn activated in 3rd gear onwards as those gears as it allowed the cat (mounted facing the front of the car) to be cooled at speed.
Old 09-27-2013, 11:02 AM   #53 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I hope the mods don't mind if I bring this back, but its a very educational thread and more people should get a chance to see it.
Well done my friend well done.
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-27-2013, 12:12 PM   #54 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
I agree. Retreading the thread makes me want to order the pulse generator!! It in my eBay list. I managed to find a p07-g01 from Germany. Still haven't tried it yet. I'm afraid running 87 octane might not be good because I believe they run higher octane in Europe.
Burn lean and prosper \\ //
Old 09-27-2013, 12:36 PM   #55 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by greasemonkee View Post
The D15B 3 stage vtec engines originally came with a one wire O2 sensor, maybe I've been missing something, but I don't see anywhere that the 3 stage was a leanburn from the factory. Nevertheless, the three valve mode has the potential to operate in leanburn to my knowledge. I almost bought this engine, but parts for an engine with Siamesed vtec spool valves?
For the skeptics claiming it will "melt" the engine to operate WOT in leanburn - Heat = pressure, thus pressure = heat. There literally is not enough of either to damage the engine. Combustion temps are cooler in leanburn producing 25 hp than at stoich fueling producing 25 hp. Flame propagation must be fast enough to minimize waste work (pressure before TDC), otherwise so much timing would be required that most of the energy released (pressure/heat) would be making the engine work against itself - the reason you can't just take any engine and expect it to run lean efficiently.
Combustion temps are known to be highest at stoichiometry and dropping off on either side of a lambda of 1. Only problem is the high oxygen content becomes dangerous at slightly-leaner-than-stoich ratios where temps are high, that is what will destroy an engine - if the heat isn't there, the oxygen is harmless.
I would be concerned about trying to squeeze off much more hp in leanburn, and I'm sure there is a point of diminishing returns somewhere along the line.
The HX engine would probably run fine on a P07 ecu, the timing tables would be out a little, but as long as the injectors were the same cc and you used the L1H1 O2 sensor it should work.
I'll look into making a fuel log, some days require a rush where I could care less about economy so to see the numbers on a graph may appear like a sawblade.
Heres some data from my Lean Burn Talon at 29:1 A/F ratio.
The first pic is the starting point where the engine just starts to go into lean burn. Notice Coolant Temp at 206*F and IAT at 92*F.
Here's the ending point of this data log. Notice the Coolant Temp at 196*F and the IAT at 90*F. From this point out the IAT will stay at 90*F until the ambient air Temp changes drastically. The Coolant Temp will actually drop another two degrees to 194*F in about two more minutes.
I have seen data logs during 95*F days in lean burn mode where the coolant will drop below 200*F and the coolant fan won't turn on anymore.
Normally my engine stock runs a coolant Temp of 210 *F.
The Following User Says Thank You to pgfpro For This Useful Post:
Xist (09-27-2013)
