Go Back   EcoModder Forum > Classifieds > For Sale
Old 03-03-2011, 07:06 AM   #21 (permalink)
Don't tell me I can't!
Battery spec sheet
Yeah I thought so. I may be missing some detail but they sent me a whole package of info. I'm no expert so here's what the data sheet said. The first part is for the individual cells and the second is for the whole pack. I was kinda surprised by the weight of the whole thing. Seemed really heavy. Please feel free to point out problems with this package.
Performance Data Individual Battery
Single Module Parameters U27-12XP
Module Capacity at 20Hr. Rate Ah 138.0
Module Capacity at 5Hr. Rate Ah 138.0
Module Energy at 5Hr. Rate Wh 1766
Module Nominal Voltage V 12.8
Module Charge Voltage(max) V 14.6
Module Charge Voltage(min) V 13.8
Module Discharge Cutoff V 10.0
Module Discharge Current Max Continous Amps 150.0
Module Discharge Current Max Peak (30 seconds) Amps 300.0
Module Length mm 306
Module Width mm 173
Module Height mm 225
Module Weight kg 19.5
Module Energy Density* Wh/L 148
Module Specific Energy* Wh/kg 91
Moudule Impedance mΩ 5
Total System Parameters
Modules in Series 5s
Modules in Parallel 8p
Total Number of Modules 40
System Discharge Voltage V 64.0
System Charge Voltage(max)^ V 73.0
System Charge Voltage(min)^ V 69.0
System Discharge Cutoff - Minimum V 50.0
Total Battery System Wt. kg 780
Total Battery System Vol. L 476
System Discharge Current Max Continous† Amps 1200
System Discharge Current Max Peak (30 seconds)† Amps 2400
Total Battery System Capacity* Ah 1104
Total System Energy* kWh 70.7
Discharge Profile† % DOD 100%
Utilized Battery System Capacity† Ah 1104
Utilized Battery System Energy† kWh 70.7
Recommended Controller Interface
Model Quantity
U-BMS-XP-LV, XP series BMU; 16 - 150V 1
Old 03-03-2011, 05:56 PM   #22 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Based on those specs its actually a bigger battery than your original 1000ahr and if the price is legit, sign me up!
I will take one.
I could probably figure out a way of making it fit in my C-car, a 200 milish range would be nice
Too bad the darn thing is at such a low voltage though, its really more of a 64v battery pack, for the type of charger I have and the type of controller I have, would be better off with one more module in series.
Those would work but my speed would not be real great. Especially near the end of discharge at 50 volts 35mph here I come.
Cheers
Ryan
Old 03-09-2011, 07:11 PM   #23 (permalink)
rmay635703's Avatar
Originally Posted by Bigswampthing View Post
I recently received a call from Valence. They actually got back to me the very next day! They were perfectly willing to give me a quote over the phone for a specific battery system that would suit may needs and indeed sell me just one. They must be getting enough interest.
Example I had quoted:
72 volt 1000 ah, capable of 1200 amps was $2500
They offered quantity discounts and several reasonably priced battery management and diagnostic units.
Battery management $345
Diagnostic kit for installers $360
Contact was: Jonnie Hefty (512)527-2909
It appears that you are mistaken the $2500 is for one of the 40 modules.
Old 03-10-2011, 07:22 AM   #24 (permalink)
Makes no sense
The quote I received was a verbal quote for my system over the phone. She may have misspoken. Even so, that would mean that this thing is $100,000. That's foolish. Oh well. back to the drawing board. Still too heavy any way.
Old 04-14-2011, 05:40 PM   #25 (permalink)
rmay635703's Avatar
OK I double checked the price by going through the whole quote process, a 110ahrx144v setup is over $19k but the BMS is cheap. I might have to buy the BMS then buy another brand of Lithium
Old 04-14-2011, 07:46 PM   #26 (permalink)
skyking's Avatar
Woody - '96 Ram 2500 SLT
90 day: 20.74 mpg (US)
Avion and Woody - '96 Ram 2500/5th wheel combo
90 day: 15.87 mpg (US)
Module Width mm 173
Model Quantity
Looking at the data sheet and reading the OP, i see a misunderstanding of battery system rating.
The battery above has a 138 AH rating. 12 of them in series will have a 138 AH rating at 144V.
He is talking about a 1000AH pack @144V
That would be 72 batteries!
The post above with a 72V 1000 AH rating would be 36 batteries. 6 series 6 parallel.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1487 05-22-2012 12:57 PM
More smaller batteries vs. Less bigger batteries GooberPea Motorcycles / Scooters 31 01-30-2011 10:44 AM
Adding batteries for longer EOC Daox EcoModding Central 25 03-17-2009 03:14 PM
GM's Reportedly Road-Testing Lithium-Ion Batteries for the Volt SVOboy Fossil Fuel Free 5 05-25-2008 02:38 PM
Johnson Controls Batteries bennelson Fossil Fuel Free 1 03-13-2008 11:28 PM
