Old 03-03-2009, 11:47 PM   #1 (permalink)
Metro
Mogal's Avatar
Guzzler - '09 Accent GSI Sport
90 day: 32.47 mpg (US)
Question Glow Shift 3 Cyl Tach in a Metro
Hey all!
(I LOVE this place!)
I just recieved my GlowShift Tach.
The wiring setup is a little different then what I kinda expected,
and would like some help with setting it up.
Theres a 4 wire plug labled as such:
Black: Engine ground
Red: Switched ignition source(+)
Orange: 12v Dimmer wire switch(+)
Green: Tachometer Signal
My question is with the green wire.
Where do I hook this one up to?
The instructions are:
The green wire get connected to your vehical's tachometer source wire. On some applications it may be necessary to use a tachometer adaptor.
What is the Tachometer Source Wire?
And do I require an adaptor for the GEO?
Shift your Attitude
Old 03-03-2009, 11:54 PM   #2 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Hook it to one of the coil wires. I can't remember what one is correct but you can always touch it to one of them and see if it is working. If not then try the other one. It won't hurt the tach being connected to the wrong side of the coil. The other option is connecting it to the coil wire coming off the ECM but that is a real pain to get to so I say hook it to the coil and save a lot of hassle.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 03-04-2009, 01:33 AM   #3 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Firefly 3dr
90 day: 40.08 mpg (US)
AFIAK, you want the ground side of the coil, possibly the black/white wire.
Old 03-04-2009, 11:37 AM   #4 (permalink)
Metro
Mogal's Avatar
Thanks Guys!
I'll be installing the tach tonight....
Shift your Attitude
Old 03-04-2009, 09:48 PM   #5 (permalink)
Metro
Mogal's Avatar
K, splicing in a moment...
I have a Black/White wire, and a Brown/white wire...
Hope nothing goes BOOM!
Shift your Attitude
Old 03-04-2009, 09:53 PM   #6 (permalink)
wikityler's Avatar
If you give me the model year and if it's MPFI or TBI, I can send you a schematic.
Old 03-04-2009, 11:07 PM   #7 (permalink)
Metro
Mogal's Avatar
The car is a 1994 GEO Metro, TBI
The engine is an earlier year... (thinking a 92/93 - but not sure)
Thanks!
Shift your Attitude
Old 03-04-2009, 11:12 PM   #8 (permalink)
Metro
Mogal's Avatar
Well, I spliced into the black/white wire, and got nothing...
Then the brown/white... started to read correctly...
But one weird thing is happening now... the idle seems high, and is oscillating between 1000 and 1800 rpms... I hear a little 'click' and then the rpms jump in speed...
Is that due to the altinator?
Shift your Attitude
Old 03-04-2009, 11:40 PM   #9 (permalink)
wikityler's Avatar
Is the engine running fast, or is it the tach that is displaying the incorrect rpm?
Old 03-05-2009, 01:09 AM   #10 (permalink)
Metro
Mogal's Avatar
With the engine cycling the way it is now, its running fast...
With the timing light(before the tach install) Idle was timed at 850rpm.
Not sure what its doing... but I'll pull the batt and reset everything... see what happens.
Shift your Attitude
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 11:00 PM
Tach swap? G13 tach in G10 car? hypermiler01 Instrumentation 6 02-11-2009 12:59 AM
Metro Owners: Optimum shift points for P&G 93Cobra#2771 Hypermiling / EcoDriver's Ed 7 02-08-2009 01:37 PM
Battery drained overnight after install of tach on '97 metro. Advice? lyd DIY / How-to 7 09-29-2008 04:49 PM
