Old 01-14-2010, 09:37 AM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
GM to offer 100% battery powered Volt (no engine/generator)
Bob Lutz has said that GM will build a battery-only version of the Volt.
Probably in response to the small number of hard core EV fans who have been debating how much weight they could save by yanking out the ICE, generator, fuel tank, cooling system...
Lutz wouldn’t say when such a car would hit showrooms, but noted the process for building it would be “technologically trivial,” and just a matter of removing the range extender and expanding the battery pack.
“Once you’ve done the Volt, pure electric is trivial. You just leave some parts out,” Lutz said.
ABC News via GM-Volt.com
Old 01-14-2010, 09:50 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I don't think they should wait to sort out the hybrid volt range extender before releasing an electric volt. I'm sure EPA and other regulatory crud surrounding the gasoline components can add serious delays.
Old 01-14-2010, 10:19 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
What? Why would they do that dcb?!? That might make sense!
Old 01-14-2010, 11:09 AM   #4 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Amazing! If they do a straight exchange of weight and/or space of the ICE, the generator, the cooling system, the fuel tank, exhaust, etc., I wonder what the range would be?
They will have to develop an additional battery enclosure.
Old 01-14-2010, 11:21 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
yup, even if it does a boost conversion to supplement the main pack, a bolt in battery block would be an obvious upgrade.
Old 01-14-2010, 12:40 PM   #6 (permalink)
Black Beauty - '09 Accord EX-L
90 day: 27.44 mpg (US)
Hmm... that will require approval of both the House and Senate.
Then calculating in consulting fees and building a new plant in China...
The new enclosure should cost just under $5,001.3234334~
Old 01-14-2010, 06:57 PM   #7 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
If they do a cost-equivalent BEV version of the Volt, what'll it have, 55 mile range instead of 40?
Old 01-14-2010, 08:31 PM   #8 (permalink)
Ecomodder en route
KITT222's Avatar
Vib - '04 Vibe base
The BEV Volt may come a few years after the EREV/Series hybrid Volt. The batteries would probably take the place of the ICE, fuel tank, and other components that are left out. May get the Volt to a 100 mile range, but I'm not certain on that. Hopefully there will be some new wheels on the BEV Volt.
"The Volt" May BE SCRAPPED!- NEVER BUILT!! Jammer Hybrids 446 10-05-2010 05:35 PM
ElectroCat lithium battery powered motorcycle NeilBlanchard Motorcycles / Scooters 7 12-16-2009 07:36 PM
News: GM planning dedicated high efficiency hybrid (in addition to the Volt) MetroMPG Hybrids 17 07-16-2009 10:20 PM
New Info On Chevy Volt Battery Matt Herring EcoModding Central 1 10-23-2008 02:19 PM
Chevy Volt and GM Get Big Boost From $700B Bailout Vote Today Matt Herring EcoModding Central 15 10-09-2008 04:20 AM
