02-26-2013, 06:21 PM
GM & others Reduced I.C.E. Friction
Link
Very slick: Automakers strive to reduce engine friction - NWautos
General Motors has quantified the overall friction reduction for three of its four-cylinder engines. The 2007 2.4-liter four-cylinder generated 46 percent less friction in low-speed driving than GM's 2-liter four-cylinder of the early 1980s, despite having more valves, a more complex camshaft drive and a pair of counterbalancer shafts. Friction reduction alone resulted in about 7 percent better fuel economy over that 24-year period.
In the new 2.5-liter four-cylinder that will power the 2013 Chevrolet Malibu, friction has been cut another 16 percent, resulting in a 2 percent engine efficiency gain compared with the 2007 2.4-liter.
Each engine developed more power per liter than its predecessor, doing more
The Following 4 Users Say Thank You to DIMS For This Useful Post:
02-27-2013, 03:07 PM
Interesting - thanks for posting that.
Friction reduction approaches mentioned in the article:
- cylinder-coating materials
In the Nanoslide coating process, the cylinder walls are sprayed with an ultrathin layer of a molten iron-carbon alloy. A special finishing process puts a smooth surface on this extremely hard coating, at the same time opening tiny pockets in the metal that retain oil for lubrication.
- advanced honing techniques (abrasive & laser based)
- smaller bearings
- straighter chain runs (camshaft chain)
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
02-28-2013, 12:14 AM
Internal coatings, optimization of the design of certain moving parts such as valve rockers, camshafts, among others, and also lighter alloys were a great advance.
02-28-2013, 07:20 AM
One problem... these new anti-friction coatings and the lightweight engine blocks mean that re-boring and re-building these engines after they blow is sometimes a problem.
On the brighter side, engines nowadays typically last longer than most people keep cars.
03-01-2013, 12:20 AM
That's a good point to consider while looking for cylinder sleeves...
03-01-2013, 10:16 AM
...beats walking...
...it's also a contention point when something goes wrong with the engine and they want to just "rebore' rather than replace the block under the warrantee!
