Old 02-16-2010, 11:36 AM   #11 (permalink)
But of course a "passive" grill block would cost a lot less and be a lot less expensive, and probably save as much fuel.
Except that you have to design for the worst case, and a passive block designed for commuting in a Minnesota winter is going to have problems when you're pulling your travel trailer up a mountain outside Phoenix in the summertime.
Old 02-16-2010, 12:34 PM   #12 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
That 48 mph average makes it easier for the bean counters to say "nay" than "yea" when it comes to cost/benefit. The % impact on EPA tested MPG is going to be less than in the real world, where people drive 70+ mph all day long.
Exactly! They will only offer solutions maximizing their return on investment. That return is determined by the added value percieved by the customer. And what does the average car buyer percieves as far as fuel economy is concerned. Yup, the sticker in the driver's window in the showroom.
That's why we don't see idle-stop much here while it's everywhere in Europe (~35% of the time in the urban part of the NEDC is idling time vs ~19% for the EPA FTP-75 cycle).
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-16-2010, 12:55 PM   #13 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
That's the old epa test. The new highway includes another high-speed test that averages 70 mph (at least for half the test). Then the two tests are averaged together for the final Highway number.
Fuel Economy Test Schedules
Old highway test
New highway test
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 02-16-2010, 01:07 PM   #14 (permalink)
Moderator
The problem with the SFTP USo6 is there is still a lot of aggressive acceleration and some stop and go involved. The average speed is the same as the old highway test. It would be nice to have a steady state 70 mph warmed up number instead. The old highway cycle wasn't bad, it just needed to be offset 15 mph.
Old 02-16-2010, 04:17 PM   #15 (permalink)
Si engine and trans
90crxHF's Avatar
CRX Si/HF - '90 CRX HF
90 day: 40.35 mpg (US)
Why stop with the trucks, GM?
As soundly minded people (hence the reason most of found this place) we have all asked this question a time or two.... There are so much in America that needs to change, companies have to attack things like grill blocks slowly, otherwise "normal" Americans will flip out. Imagine if Americans cared more about the place around them than how late and how uncomfortable they are??? I used to drive fast, everywhere and of course the one person driving sanely simply pisses people off to no end, but now, I don't do that. In fact my commutes are pleasant and peaceful now. No stress. It's strange how simply slowing down, being fuel conscience can have a very positive effect on someone's life. I just wish the people that claim to be smart, would in reality prove it by realizing the error of their ways... I finally did (however I'm not claiming to be smart, however I am claiming that I can still learn)
~1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race
1/8th: 9.90 @ 71.03, 60' - 2.41 (HMP '08) - 284K on chassis and ~110k on engine
~1996 Mustang GTS/248A - 1/4: 13.447 @ 99.75, 60' - 1.820 (HRP - 959' DA)
http://www.nearlysurrounded.com <-- Check out my band
Old 02-16-2010, 06:57 PM   #16 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Yes - it would be interesting to see MPG of both the "highway" tests with the same vehicle.
Old 02-17-2010, 09:15 AM   #17 (permalink)
Huh. I didn't notice the average speeds being so similar. Still, it will show the effects of gear ratios and aerodynamics more clearly than before.
GM to use active aero grille block in pickups MetroMPG Aerodynamics 3 01-22-2010 05:30 PM
Cowl block - similar to grille block MetroMPG Aerodynamics 5 07-19-2009 04:15 PM
Partial grille block - Fully duct tape jesse.rizzo Aerodynamics 12 02-18-2009 05:12 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
