Old 03-09-2010, 11:37 PM   #21 (permalink)
Originally Posted by IsaacCarlson View Post
I don't have any problems with manual steering in my car... and it weighs almost 3800 lbs!
Back in my younger days, I spent a summer running a D7 Cat - about 50,000 lbs depending on model - for a logging crew. If you're not familiar, they steer with two levers that operate slip clutches on each track. When I started the job, I thought they pulled a little hard, but as the summer wore on I got used to it. Then in the fall we hauled all the equipment back down to the valley, the company mechanic hopped on to unload my cat, and started cussing "What the @#$! did you do to the power assist on this b**ch?"
So you see, you don't really need power steering even on slightly heavier vehicles :-)
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 5824 Yesterday 04:25 PM
Electric Power Steering pump okrent3209 DIY / How-to 12 05-14-2012 04:00 PM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 66 03-28-2012 08:06 AM
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 07:53 AM
Electric Power Steering w/o hydraulics sirus20x6 EcoModding Central 22 03-07-2011 10:00 AM
