Register
Now
Reply
Old 05-26-2008, 03:36 PM   #1 (permalink)
Pb-Blaster
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 29.14 mpg (US)
S10 - '95 S10
90 day: 27.44 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 124.07 mpg (US)
Going for FOUR
Hey guys.
I am going to try rigging up the cycle with four batteries today.
I have decided to have the two upper front batteries side-by-side, sticking out a little bit.
I have some "unistrut" I got at the Home Depot - $10 for 10 feet. Nice strudy stuff, but it cuts fine with a hacksaw, and it comes with holes in it for bolts.
I will snap some pics as I work on it, so you can see when I am done.
Somewhere around, I have an old, hand-held GPS. I would love to find that to test against the speedometer. I don't trust the speedometer accuracy.
-Ben
Old 05-26-2008, 03:51 PM   #2 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 45.63 mpg (US)
Daox's Matrix - '03 Matrix
90 day: 38.15 mpg (US)
Very cool Ben. That should hopefully get you up to 45 mph don't you think?
EcoRenovator.org - Efficient living and green home improvement
Matrix Build Thread
Paseo Build Thread
Old 05-26-2008, 06:01 PM   #3 (permalink)
Pb-Blaster
bennelson's Avatar
S10 - '95 S10
Yeah, I am guessing that with the 48V system, I should be able to do 45.
Also, my DC/DC converter cuts out below 32 or 33 volts, which is easy to do under load when the batteries are run down a little on the 36V system.
48V should keep my converter from cutting out and killing my lights at night. Not that I do much night riding, I would still rather not have that happen!!!!
Old 05-26-2008, 07:32 PM   #4 (permalink)
Pb-Blaster
bennelson's Avatar
S10 - '95 S10
New Cycle Specs!
New System Voltage: 48V
New top speed: 47 MPH!!!
Ouch! That bug hurt when it hit me!
Old 05-26-2008, 07:53 PM   #5 (permalink)
Moderator
Awesome!
...but you forgot pictures.
Matrix Build Thread
Paseo Build Thread
Old 05-26-2008, 09:33 PM   #6 (permalink)
Pb-Blaster
bennelson's Avatar
S10 - '95 S10
I went for a 21.5 mile ride! Why? Because I could!
Went up the big hill at 40 mph and then down it at 52. Zipped around for a while.
LOTS O' FUN!!!!
Check out more pix here:
http://web.mac.com/benhdvideoguy/iWe...hotos%202.html
Scroll down a bit to see the new ones.
I don't like the look of the cycle quite as much with the batts sticking out, but I sure like the speed and range!!!!
Old 05-26-2008, 10:21 PM   #7 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
90 day: 54.79 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Awesome :-)
21 miles becomes useable on near everyday status for me.
What if you modified the front 2 tubes? Would you have space then?
Old 05-27-2008, 09:53 AM   #8 (permalink)
Looks good. The only thing I would suggest is to angle and round off the edges of the unistrut stuff. It looks like it would hurt if it hit your leg in the wrong spot.
Old 05-29-2008, 10:59 AM   #9 (permalink)
Pb-Blaster
bennelson's Avatar
S10 - '95 S10
Yeah, I have to file down the edges.
I have a few other things to do as well. My plan was just to put it together like this to test the functionality, make sure the batteries weren't in the way of my legs or feet, etc.
I will pull this back apart, paint all the metal black (to match the frame) and install lock-nuts and washers.
Since I removed all wood parts from the cycle (except the very bottom plate) I no longer have a place to screw down the master power contactor - so that's just "floating there" right now too! I will need to make a little something for that to mount to.
I am also waiting on the new 48V charger, so I won't do anything until I get that and decide where it goes too.
Reply
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
