EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   Gold Fault Laser (https://ecomodder.com/forum/showthread.php/gold-fault-laser-36291.html)
freebeard 03-24-2018 03:05 PM
Gold Fault Laser
When I saw this I thought of The Unicorn Corral. Gold Fault Laser – BLDGBLOG
In the general chaos of renovating a house here in Los Angeles, I missed this lecture and reception on Friday night, launching a semi-fictional “Geothermal Futures Lab” at SCI-Arc.
It involves installing a gold-plated laser somewhere deep in the San Andreas Fault to extract geothermal energy from the landscape.
The word salad is beautiful to behold. :)
The exhibited technology capitalizes on the unique tungsten-saturated substrate of the San Andres fault through the use of a visible-light Q-switched Nd:YAG lasers, tuned to extract sustainable magno-electrical energy from a +678 degree Kelvin supercritical water deposits located adjacent to a stable magma chamber 4.4km beneath the Earths surface. This supercritical water, that behaves both as liquid and gas, is vaporized through 3,780 Kelvin bursts which at peak power induce a supercritical matter state releasing energy in exponential excess of its matter equivalent. The presence of heterogeneous frequency fields in metal deposits along the strike-slipping continental plates supercharges the pockets of supercritical water with magnetic nuons which are forced upwards with velocity µ as a result of the pressure gradient along the vertical faults.
"Semi-fictional' prevents it being fake news.
