Good news everyone! I made a grill block!
3 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1369616080http://ecomodder.com/forum/attachmen...2&d=1369616080http://ecomodder.com/forum/attachmen...5&d=1369616303
Edit: I barely drove two miles and was not yet on the freeway when my Ultragauge began warning me of overheating, so I removed this and decided to try again later. Unfortunately, I had already given up when I realized that the Ultragauge itself was overheating, not my car, although my engine must have been warm if I turned on the heater--the Ultragauge was right in front of a vent. Also, it seemed impossible to shrink the plastic without creating holes. Despite having most of the plastic left, I have never wanted to attempt this again because even Ecomodders were ridiculing me. Original post: This was an abject failure. It was It was 89°F and 81°F when I did my "A" drives on a 51.3-mile route, 46.1 miles on the freeway and 92°F when I finished the grill block and attempted the "B" drive, but my car started overheating before I got on the freeway. I tried again at sunrise, when it was 66°F, but my engine reached 219°F and I got 31 MPG compared to 31.4-31.5 for my "B" runs, with a cooler engine. The idea was that the plastic would be less noticeable and I chose the aluminum tape because I thought that it would withstand my heat ray better, but it certainly is visible, especially with the pieces covering the random holes. I do not know if it is possible to shrink the plastic tight without creating holes. I do not plan on using this material again. I did my baseline run just after 1pm. I live 2.6 miles from the freeway entrance and I chose a loop that allowed me to stay on the freeway as long as possible. A: 89°F Precipitation: 0% Humidity: 7% Wind: 4 mph [according to Google, not everything can be deduced] I put my Ultragauge on page four so that I could see my engine temperatures. They stayed between 192 and 199°F as I accelerated to seventy and coasted to fifty. Curiously, the engine cooled seven degrees as I accelerated and then warmed back up as I coasted. Note: Eighty-nine outside, no functioning air conditioning, so I was sweating. I probably should have used ear plugs and rolled down the windows, but I would not have gotten: 31.5 MPG (Not fully calibrated). B: 92°F Precipitation: 0% Humidity: 6% Wind: 2 mph My Ultragauge started screaming before I got on the freeway, so I slowly drove home. So much for the hope that my car would be so aerodynamic that it would run cooler. Hopes are not always rational. I had planned on installing a fan indicator. As we discussed elsewhere, run wires from the fan fuse through the firewall to an LED where I could see it. Would I need to do anything special? Someone wrote that you always wanted to put... something... (a fuse?) ...whenever you added wiring, and they talked about speaker systems. I did not figure out the details beforehand, so I decided to do it later. |
very clean!!!
Second attempt:
Tempe, AZ Monday 7:00 AM Mostly Cloudy 71°F Precipitation: 0% Humidity: 18% Wind: 0 mph Everything was warmer than my "A" run yesterday as I approached the freeway, cool enough for me to make the attempt, but warm enough that I turned on my heater, having forgotten two very basic details: UG°F refers to the temperature of my Ultragauge device, and my vent blows directly on it! I will probably try again later, once I purchase more foil tape. If I leave out the grill block, I should be able to drive when it is around the same temperature that it was yesterday, but if I actually drive at 5am tomorrow, I should be able to drive with the full block. I hope that I did not damage the plastic too much. |
As a bonus it also protects your car from chlamydia! :D
Interesting experiment, also known as the car condom.
I love foil tape. |
I sure would have saved myself some time had I known this would be the result.
So, do you guys think that the all-in-one upper- and lower-grill block, fog lamp cover, and gap seal will work? Do you think that my engine will be able to keep itself cool at sunrise, or will I need to remove that section? Do you have any suggestions? Have any of you tried blocking this much at once?
It's a unique (!) approach, but in summer temps, a 100% block is too much. You'll need to open it up some.
