Old 11-09-2009, 03:55 PM   #11 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Sometimes those tire shops forget to clean the oxidation from the rim bead seating area. This will cause leaks, lead to underinflation, and eventually a blowout.
Old 11-10-2009, 08:08 AM   #12 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 32.27 mpg (US)
I had heard of this dot thing...but didn't know the details. The Vivas did not take more weight than the Kumhos I had on the same wheels...and the Kumhos did not seem to need balancing up to 55 mph...though I did them anyway.
I learned how to mount and balance by watching the tire guys do it and trial and error...takes some muscle...but you need to keep the old thinking cap on at the same time.
You don't want to tear the bead up or stretch the cord at the rim.
Dropped the PSI to 40...waiting for those blowouts.
Also waiting to see if I have any bead leaks...so far so good.
Originally Posted by bikin' Ed View Post
about mounting tires yourself is that you can do it properly. Most people don't realize that tires and wheels can not be made perfectly round. Manufacurers have agreed to make the low spot of the wheel at the valve stem, and the high spot of the tire will be marked with a dot. If you align the dot and the valve hole you get an almost perfectly round unit.
Properly aligned tire/wheel units last longer, run cooler and longer, and require less weight to balance.
Old 11-10-2009, 08:14 AM   #13 (permalink)
The Escort steel wheels these were put on had a certain amount of rust and roughness...decided not to try sanding...since my one experience trying this was not good. I just clean them up using a dish washing scrubber and use NAPAs blue goo when mounting. If I have a bead leak...I can mark the place...break the bead and apply some non hardening gasket goop to that area.
Some use axle grease if they have problems...but if you ever have a tire spin on the rim...you are SOL.
Old 07-01-2010, 10:19 AM   #14 (permalink)
I like these tires (I installed 4 used ones)...but had one develop a sidewall bulge...and so replaced it with another brand of used tire.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 38 04-13-2011 07:12 AM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
My Continental Contact-Pro Tires cfg83 EcoModding Central 16 05-08-2010 02:33 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
LRR Viva 2 tire results RandomFact314 Success Stories 10 08-06-2009 11:27 AM
