Got a few MPG from new wheels and tires and lowering springs
Car is a 2003 Honda Civic Hybrid with 237k. I was getting 48.4 all day long with the factory wheels and some junk tires. Put a set of Konig Helium Ultralight rims with Zeix 512s on there. 4lbs lighter per wheel! Running 42psi front and rear. That took her to 48.8.
Also lowered it 1.3" with a set of Skunk 2 springs for another few points, currently getting 49.2mpg. And that's all without the IMA system working yet!! Goals; get the IMA working, maybe install an MIMA, and try some LRR tires on the factory rims. Might try making a belly pan for it too, there's definately some drag on the underside where the back of the K frame is and a HUGE pocket where the muffler is. |
Such small increases are hard to quantify but yeah that's how the wheels and springs mods are supposed to work.
Congrats on the increasing numbers. Are those numbers from tank or trip data? I was thinking about buying a set of 03-05 hybrid wheels but then found out they weigh around 14-15 lbs. Not very good for a 14 inch wheel. I'm still looking for a set of HX wheels to convert it back to stock.
Are the civic hybrid wheels really that heavy? I was thinking about getting a set but if they weigh that much then it's not worth it.
I remember the first time I saw a first generation Insight new at the dealership. All I could think about when I looked at it was: Over $21,000 for that!!!! :eek:
Hindsight being 20 / 20, I coulda', shoulda'..........rats. Another opportunity lost to lack of education. |
The stockers are pretty heavy. An older set of HX wheels is the way to go if you want factory. They're super rare these days.
I'm assuming they beefed up the wheels because the cars are heavier and if you tag a pot hole they don't want the wheel breaking apart and you crashing the car. My Heliums are only rated at 500kg a piece. So 1,100lbs, and given a curb weight of 3,500 I'm not in the "danger zone" but close. |
