Great awful commute fuel economy
Car is running great since I did the head gasket job, flushed my cooling system, installed 15" wheels for the taller gearing, and made the rear wheels quite smooth to the airflow.
I drove a 130 Mi round-trip yesterday for work that averaged 64 miles per gallon. But what was most fun about it was that I did very little engine off coasting. I did at least 50 miles of steady throttle cruising. I did some engine on coasting. And my EOC was mostly in the stop/go LA traffic. Before the repairs and the new wheels, I had noticed a breaking point in the fifth gear cruising characteristics of the car that looked like this: it wasn't possible to stay at or over 60 miles per gallon if I was at or over 40% engine load and it also wasn't possible to stay under 40% load if I was trying to travel over 55 miles per hour. Now I can do 60 miles per hour at 60 miles per gallon at 45% load. 40% load has become the breaking point for 70 miles per gallon. |
Looking good! I wish my car did that well on the highway... so all that you done was the head gasket and taller tires?
I don’t call that lugging, I call it good tall gearing... on two lane roads I P&G up to 60(2200RPM) and back down to 40(~1500 RPM)... on the freeway I cruise at 75-ish at just under 3000... my speedo is uncalibrated for my tire size increase of 5.3% so I’m sure I’m driving faster than I need to... however, on the topic of lugging, I’ll use engine power from as low as 1000 RPM in 5th gear, and from as low as ~800 in 4th and down... I feel that the key is to slowly roll onto the throttle and only use 40-50% load until you’re under way and over 1000
http://ecomodder.com/forum/attachmen...1&d=1523916431 I thought it looked a little better than just using moon eyes. EDIT: here it is I'll upload it for you if you haven't seen it: http://ecomodder.com/wiki/images/e/e...FC_cleaned.png |
Well of course you are getting better mpg now, your valvetrain was probably worn, now it's basically a brand new head with way less leakdown. Also, I'm going to assume you had the head shaved to make it flat again? If so, that's also a small compression bump. Not much, but everything counts I guess.
I think the general lesson might be that you could be leaving some potential untapped with the 40-50% load, high gear acceleration you described. On the map I posted above--and some others--50% load at 1000 rpm is in the 325 band, whereas if you down shifted and hit 75% load at maybe 2500 rpm you would be in the 250 island. That is maybe 20% more efficient. I got that right, yes? |
Anytime else that I’m accelerating and over 1k, I usually flatten the pedal, and UG reports 78-82% load...yes I do know that if I backed off a little I could accelerate in closed loop... sometimes I go the extra and can get better mileage hit usually I don’t |
