Old 09-22-2008, 04:35 PM   #1 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
Great Stuff expanding foam?
Anyone think of using this to seal up gaps and then just painting it?
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 09-22-2008, 07:32 PM   #2 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I'm planning on using it to fill in the top grille and some vanity holes in the body kit on my xB, cover with a skim coat of bondo, then painting it all rattle-can flat black.
When I do eventually get around to doing this, I'll be sure to post here.
Old 09-22-2008, 07:41 PM   #3 (permalink)
Accord - '97 Accord EX
90 day: 36.14 mpg (US)
Steve - '07 Rebel
90 day: 72.5 mpg (US)
i was thinking about using that to fill some of the gaps under the body like around wheel struts and stuff where it would not be visible. it easily be carved to shape. i vote its good stuff
Old 09-22-2008, 07:58 PM   #4 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Make sure it doesn't get sunlight on it. It almosts melts in UV radiation.
Make sure it is well-supported. It isn't very strong by itself. It does adhere to literally anything - including Teflon.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 09-22-2008, 07:58 PM   #5 (permalink)
Whoop's Wheels - '89 Civic Wagovan
90 day: 39.09 mpg (US)
You can use it to fill gaps. Just make sure that whatever gap your sealing you do not, ever, ever want to unseal. Also make sure you use disposable gloves. That stuff sticks like mad and once it is stuck the only way to unstick it is to cut, saw or sand it off.
Old 09-22-2008, 11:30 PM   #6 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
It may work as the OP has suggested, but may not be a good material for large, built-up type construction. I've read several threads where it hasn't worked as well as hoped. The latest I can recall is MetroMPG's kammback.
Project: making a permanent Metro Kammback extension
See post #66.
The two-part stuff that is mixed together may work better, like the thread showing an artist and his highly modified car:
Example of polyurethane foam car "sculpting"
But I've never used any of this stuff.
See how smart you can get by reading threads on ecomodder.com?
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 09-23-2008, 08:42 AM   #7 (permalink)
Any one have other suggestions about what to use to fill gaps? What about silicone?
Old 09-23-2008, 09:35 AM   #8 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
I like outdoor clear silicone for sealing and adhearing things to my bicycle. It holds great, yet can be peeled off without too much trouble. I has withstood winds in excess of 75 mph and remained in place.
Old 09-24-2008, 07:33 AM   #9 (permalink)
You mean like the silicone you can get for sealing bath tubs? What would be the best stuff to get? I'm not looking to build on this, I just want to seal up all the gaps in the front, but be able to paint it so I looks half decent.
Old 09-24-2008, 09:34 AM   #10 (permalink)
Boxhead
Boxy Brown - '04 xB
Great Stuff used to make a black expanding foam for landscaping (like garden ponds and such-- my dad has used it in his), but it appears they don't anymore. Reading the Great Stuff site, however, they do specifically recommend painting the foam in applications exposed to sunlight.
I have, however, found this:
Pur Black NF Expanding Foam - Foam Products - Pond Accessories
It seems kind of pricey, but is meant to be used outdoors, and will allegedly withstand heat, cold, moisture, and light.
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
Example of polyurethane foam car "sculpting" MetroMPG DIY / How-to 60 08-16-2010 07:15 PM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
Save energy with DOW Great Stuff Foam... rgathright Saving@Home 0 09-19-2008 11:33 AM
Expanding, sprayable foam as an aero construction / shaping material MetroMPG Aerodynamics 9 01-12-2008 12:13 AM
