Old 10-07-2009, 03:43 PM   #11 (permalink)
White 4Runner - '98 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '011 Jetta
90 day: 42.45 mpg (US)
Keep us posted on your FE after your trip.
Old 10-11-2009, 03:58 PM   #12 (permalink)
Zuma - '04 Zuma
90 day: 72.37 mpg (US)
Aveo2004 - '04 Aveo
90 day: 36.45 mpg (US)
Well, I just got back from my trip, and I got 5 pretty good tanks with the car. I checked my tire pressure a while back and it was 30, with a recommended max of 44, so that explains my 33 mpg on my first few tanks. I went up to 48 psi for the trip, also had the grill block on the top grill, and the passenger mirror folded in.
I broke 40 mpg for one of the tanks, but there was probably a net downhill on that leg. Averaged about 37 mpg, I'll take that since the EPA mpg is 31. Now I'm hooked though, I want to block a bit of the bottom grill, as well as the fog light holes on the sides, and maybe make some wheel skirts.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 07:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 04:09 PM
