Old 11-01-2008, 09:56 PM   #11 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
yeah, i wouldn't be able to run my corner lights beside my headlights.. their attached to the grill..
Old 11-04-2008, 11:43 PM   #12 (permalink)
herp derp Apprentice
saturn - '99 sc1
90 day: 35.67 mpg (US)
i was thinking more of just the section that is the actual grill. might be a little more work, but i bet u could create some nice looking options.
Old 11-05-2008, 01:08 AM   #13 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Originally Posted by trikkonceptz View Post
If your goal is heating and not aero, consider using a flat piece of anything and experiment with different cut out sizes and block the radiator directly, from inside the engine bay. If you are looking for aero upgrades then follow the suggestions of our fellow members.
I used a custom piece of cardboard for years on a Chevette
in fact the same crappy piece of cardboard - for years
but it was for my warmth, not performance, worked great - covered about half the radiator
as for materials:
have you considered the 1/2" foam used in interlocking floor mats
they can be cut, sanded and painted as you like
they can be pressed in & pulled out of the grill easily
I used this kind of system to optimize my summer grill blocking
Concrete
Start where you are - Use what you have - Do what you can.
Old 11-05-2008, 02:52 AM   #14 (permalink)
EcoModding Minded
Chris D.'s Avatar
I saw some sort of rubber foam material used in bobcat parts for shipping and I'll snag a
few sheets because we just end up tossing it.. It looks promising for resin and glass..
Originally Posted by Concrete View Post
as for materials:
have any pictures of this? have no clue whats what..
Old 11-05-2008, 10:01 PM   #15 (permalink)
Sequential
Concrete's Avatar
yep
foam mat - (I think from Lowes) / summer block / winter block - see below
for frame of reference this is a 2000 S10
upper grill is permanently blocked with formed plastic
lower block is foam - cut, edges sanded smooth and painted black
rather modular setup, I could pull the foam plugs at a stop light if needed
Concrete
Old 11-06-2008, 01:29 AM   #16 (permalink)
EcoModding Minded
Chris D.'s Avatar
cool idea..
how large do they come in?
Old 11-06-2008, 06:40 PM   #17 (permalink)
Sequential
Concrete's Avatar
about 2'x2'
Concrete
Old 11-07-2008, 10:18 AM   #18 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Same as what I use. I had some on hand already, so I can't say about cost.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 12:30 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
