Old 10-29-2008, 04:11 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
grill block? expansion foam? need ideas..
I have a Tacoma pickup..
I need to block my grill because the temps are getting low and my regular running water temp is getting lower and lower..
due to the style of my grill, i'm thinking of laying something over it and trying my luck at making a grill plug from the outside and try that..
unless anyone else has any ideas, what are your thoughts?
Old 10-29-2008, 08:16 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I'd go with coroplast or plexiglas over the grill similar to what I did with the Matrix. Its quick, easy, and looks good. Check the the build link in my sig for more info.
If you want something easier, theres always tape.
Old 10-29-2008, 08:47 AM   #3 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Clear packing tape works if you want to test before doing something more permanent. My upper grill block works as does the lower (which needs a little redesign 'cuz it works too good right now).
Old 10-29-2008, 09:00 AM   #4 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
sometimes the quickest easyest fix is to put a sheet of coroplast behind the grill.... give it a shot of black paint and noone will know it's there.
not aerodynamically perfect, but it does keep air out of the engine bay, and it looks good.
so it curest most of your problems right away while you have time to look for a more elegant solution.
even a sheet of cardboard or a plastic bag will bail you out
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 10-29-2008, 03:32 PM   #5 (permalink)
Decorative stainless steel grill cover
Have you looked for one of those? Seems to me that every second Ford or GM has them around here. They are usually vented with dozens of little holes or slots but I imagine that they do a good job of grill blocking - and work as winter fronts for part of the year as well.
Old 10-30-2008, 03:38 PM   #6 (permalink)
Pipina - '93 Civic CX
90 day: 46.88 mpg (US)
I used carboard-then expanding foam-covered by plexiglass it looks really good clean-almost factory
i drilled no holes or cut anything on the car so when i sell my car no one will ever know it was there
link-http://www.cleanmpg.com/forums/showthread.php?t=16808
Old 10-30-2008, 04:35 PM   #7 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
If your goal is heating and not aero, consider using a flat piece of anything and experiment with different cut out sizes and block the radiator directly, from inside the engine bay. If you are looking for aero upgrades then follow the suggestions of our fellow members.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 10-30-2008, 06:34 PM   #8 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 18.61 mpg (US)
You should try blocking your lower vent with an idiot on a bicycle... Sorry, I couldn't resist.
I think the metal sheet sounds like a really good idea. You could easily drill holes and attach it with brackets that go around those posts in your grille.
Lol, It wouldn't even look like an aero mod, people would probably think it was just for looks.
Old 11-01-2008, 05:47 AM   #9 (permalink)
EcoModding Minded
Chris D.'s Avatar
well, I'm looking for form, function and looks as well as heating and areo..
I want it all..
as for suggestions from fellow members, thats why this post excists
I'd like make something that wont ruin the grill or cause rub marks..
Its a little rough on the bumper, doesn't work well
Old 11-01-2008, 07:59 PM   #10 (permalink)
saturn - '99 sc1
90 day: 35.67 mpg (US)
looked into what it takes to remove your current grill? removing it might do more than just save the grill, it would open up more/different possibilities for how you mount the grill block.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 01:30 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 06:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
