Old 08-19-2014, 01:22 PM   #81 (permalink)
darcane's Avatar
Originally Posted by darcane View Post
Reposting links:
Early Grill Block (less effective):
Final Grill Block:
Belly Pan pics:
And these pics show wheels, before and after:
My old website is permanently dead, so pics are now uploaded on EM.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
aerohead (08-19-2014)
Old 08-20-2014, 08:15 PM   #82 (permalink)
0.29 Cd and decreasing
Red Rocket - '90 honda CRX HF
Team "Old SKOOL"
90 day: 53.46 mpg (US)
For the front belly pan in the 6th picture wouldn't you want to put the coroplast above the lip of the front bumper instead of below?
Old 08-20-2014, 08:33 PM   #83 (permalink)
darcane's Avatar
Yep!
It's a little hard to tell in the picture, but it is installed exactly as you say. The lower fascia curves underneath the truck and you can see the steel frame is mounted to the top side of that lower fascia. Right at the trailing edge of it, it drops down just enough to really wedge the coroplast into it. It never drooped down for as long as I owned the truck. Actually, the whole belly pan was in great shape for the three years it was installed before I sold the truck.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
aerohead (08-21-2014)
Old 08-20-2014, 11:19 PM   #84 (permalink)
grey panther - '02 Mercury Grand Marquis
Team Panther
90 day: 27.15 mpg (US)
Try mylar from a hobby shop in many colors or a diamond plate print mylar at the autoparts store. It will take a car wash, but not a direct stone strike. Light, cheap and easy to install and remove.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
