Old 06-22-2008, 12:59 PM   #1 (permalink)
MPG...what?
Malibu1 - '79 Malibu Classic
Malibu4 - '79 Malibu Classic
Terkle - '97 Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '010 Yaris base
90 day: 46.84 mpg (US)
Zoey - '95 Protege LX
90 day: 31.19 mpg (US)
Send a message via AIM to malibuguy
grille blockers...
for the people who run grille blocks, how much did you pick up in mileage???
i want to make 'em for the Caliber...but they would have to be behind the grille, since its technically my mothers car & she loves the grille, so are they worth it??
I'll have to try to sneak some behind the grille if they are worth it
-Greg...the exhaust freak.
www.mandrelbend.com <-- I work there!
Old 06-22-2008, 01:15 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
I got ~2-3mpg on my best mileage, and the average is up by at least 6mpg.
Old 06-23-2008, 08:50 AM   #3 (permalink)
BBsGarage's Avatar
BBsRide - '06 Corolla CE
90 day: 31.64 mpg (US)
I found more consistency in fuel mileage after adding my behind the grill upper grill block.
I would bounce around by up to 3 mpg prior to the block. After the block I was within a mile of 40 mpg every tank full.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 06-23-2008, 01:14 PM   #4 (permalink)
EcoFocus
EcoFocus - '06 Focus SES
90 day: 27.77 mpg (US)
EcoSienna - '05 Sienna LE
90 day: 18.77 mpg (US)
Eco Monterey - '04 Monterey Luxury
90 day: 13.27 mpg (US)
EcoOutback - '98 Outback
90 day: 18.12 mpg (US)
Seem to me that improvement must be vehicle specific and modification specific. Some grills are larger than others. Cobalt comes to mind as a smaller grill.
I assume, when we call it a "grill blocker" this is specific to the cooling air intake above the bumper. Of course, on most vehicles, there is a larger cooling intake below the bumper(or integrated).
RabbitM
Old 06-23-2008, 01:30 PM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The grill block is one of the most cost effective mods you can do. Not only is it cheap, but its also pretty easy. Its hard to beat that combo.
Old 06-23-2008, 01:59 PM   #6 (permalink)
NewBlue - '07 Civic EX
90 day: 38.13 mpg (US)
The Better Half - '97 Ranger XLT
90 day: 25.84 mpg (US)
I did two 65mph cruise control tests of 300 miles (same direction same road) and got 5.72mpg better on the grill block run. Even with a margin of error for wind there is still a significant improvement, that was with fog lamp covers and lower grill block.
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
Old 06-23-2008, 02:18 PM   #7 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
A grill block was my first aero mod, about 30 cents worth of clear strapping tape over the grill inlet. Started out by blocking half of the opening, then blocking it completely when it didn't overheat. I ended up having to reopen a 4" x4" opening when summer arrived. Later I integrated the grill opening into the nosepiece I added to the front of my car.
aerocivic.com
Old 06-23-2008, 07:43 PM   #8 (permalink)
homeworkhome53's Avatar
Workride - '07 Aveo5 SVE
90 day: 51.74 mpg (US)
The grill block was the first thing I did after finding ecomodder. I ran it for two months. I could not say that the block added anything to my mpg because I was doing other things in conjuction with it. I had to take the car for repair after hitting a deer and removed it before taking it to the insurance guy. Didn't want to have to explain it. I've been running 4 months without it and noticed no loss of mpg in fact milage for last tank was 49.3 (started at 32.5). The mpg improved nearly every tank since removing it. Any improvement was small with the block. I seem to be coming to an impass as the last five tanks have all been 48-49 mpg. Maybe a better intrigrated block would help me to break 50. I've been thinking of building one out of spray insulating foam and the shaping it more aerodynamic and painting it to match and adding a belly pan.
homeworkhome53
Old 06-24-2008, 07:17 AM   #9 (permalink)
MPG...what?
RabbitM
thats what i was thinking, the caliber has a huge grille, grabbing too much unwanted air
what you can't see, is that about 1/3 of the grille is blocked off from the factory, & the lower openings are blocked also besides for the ones right around the tag
i should wait 'till my scangauge arrives, before i try anything
Old 06-24-2008, 09:46 AM   #10 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Using clear packing tape, my per tank average increased by ~2 MPG.
DIY Vibe Grille / Fog Deletes trikkonceptz DIY / How-to 20 04-27-2011 02:27 PM
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 05:13 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-30-2010 11:21 PM
Hybrid Grille Block/ HGB Hybrid Effects Aerodynamics 0 03-22-2008 08:53 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
