Old 05-27-2010, 08:54 PM   #1 (permalink)
texanidiot25's Avatar
Formula - '96 Formula/Trans-Am
90 day: 19.31 mpg (US)
Grille blocks, behind the grille?
I'm going to attempt a partial grille block on the CRX, as well as construct a ducting that forces what air does go through the grille to the radiator. The HF's is TINY, and I want to make sure it gets all it can.
But, I don't like the look of grille blocks outside the grille. In theory, for the changes we are looking at would there be any real negatives to having it mounted just behind the grille opening, flush the the grille's "teeth", to say?
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 05-27-2010, 09:05 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
..."best" is in front of grill, as part of "smoothly-integrated" contours; usual "compromise" is behind the grill, for both "easiness" and "invisibility" reasons.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 05-27-2010, 09:08 PM   #3 (permalink)
In short, the differences are fairly negligible?
I can understand the ideal solution is to have air hit a smooth surface, but if I'm not mistaken the main goal is to keep excess air out of the engine bay and etc.
Old 05-27-2010, 09:11 PM   #4 (permalink)
...beats walking...
...depends upon how many decimal places you assign to "negligible" (ha,ha)
...actually, there will be air splillage and burble with the "behind-the-grill" that you wouldn't get with a smoothly integrated "before-the-grill" installation...plus, lots more "under-the-car" air being forced downward.
Old 05-27-2010, 09:21 PM   #5 (permalink)
Ecomodder
Fr3AkAzOiD's Avatar
Cobalt XFE - '08 Cobalt XFE
Team Chevy
90 day: 54.89 mpg (US)
'08 XFE average for 2012 - '08 Cobalt XFE
'05 Malibu V6 Tow Vehicle - '05 Malibu LS V6
90 day: 30.07 mpg (US)
I have a behind the grill plexiglas lower grill block.
What I have noticed is that at even with a piece of metal bar behind it securing it to the grill it will flex at highway speeds letting air around edges.
I used my air compressor at a low psi to confirm this.
So not only do you have smooth surface vs "toothed" surface, when a block is on the outside and gets higher air pressure it just pushes the block even further into place where as if it is behind the grill it may flex and allow air into the engine bay.
I too am thinking of setting up a system to direct the air into the radiator but that is a little farther down the road.
Lifetime mpg
2012 mpg
Old 05-28-2010, 07:18 AM   #6 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
"Lots"?
Old 05-28-2010, 11:59 PM   #7 (permalink)
A few tenths wouldn't bother me. But I didn't take into account wind trying to bypass... I'll have to experiment.
Chevy AVEO: Adding grille blocks and air deflectors Thymeclock Aerodynamics 11 01-02-2010 04:39 PM
Grille Blocks in the Summer 99LeCouch Aerodynamics 60 10-13-2009 11:19 PM
grille blocks, fan kicks on malibuguy EcoModding Central 12 01-20-2009 01:04 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
