Old 09-13-2017, 09:21 PM   #31 (permalink)
mild-mannered civic - '97 Honda Civic LX
90 day: 33.01 mpg (US)
Stubby79, I didn't mean to sidestep your comment. I'm ok with running over 181F, but 200+ while cruising is a little warmer than I am comfortable with. I'll have to keep playing with it until I get it just right. I think if I block all the air going around the radiator, so more goes through it, I might be able to put the passenger block back on and keep the coolant under 200.
Old 09-14-2017, 12:17 AM   #32 (permalink)
Ecomodding amateur
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl
Team Chevy
90 day: 16.8 mpg (US)
the old bike - '83 Kawasaki KZ1100
90 day: 37.44 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
90 day: 59.71 mpg (US)
I believe it was BamZipPow, but the pictures on his thread are down. Someone made a channel like I think you are talking about. It just seals the gaps between the front of the car and the radiator so that no air escapes around it.
Also if you haven't seen it already:
File:KorffIntakeDuct.jpg - EcoModder
BTW you should consider adding yourself to the ecomodder user map if you haven't already. https://www.zeemaps.com/map?group=1047848
Good luck
At 55 mph, a 10% drag reduction translates to a 5% increase in fuel economy. At 70mph,a 10% drag reduction translates into a 4% increase -Phil Knox (Aerohead)
The Following User Says Thank You to M_a_t_t For This Useful Post:
Daschicken (09-14-2017)
Old 09-14-2017, 07:51 PM   #33 (permalink)
Thanks for the pic M a t t.
That's really close to what I was thinking (maybe a little fancier than what I had in mind..back to the drawing board!). We aren't too far apart. We were just down at Johnny Carino's in Muncie last weekend!
I'll have to get myself of the map.
Old 02-01-2018, 10:31 PM   #34 (permalink)
I installed a warm air intake. Intake temps went from ~10F over ambient to ~60F over ambient. Mileage went from high 20's to mid 30's.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
