Old 10-30-2009, 12:51 PM   #1 (permalink)
Draco - '89 F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
Had to drop air pressure
running at 45 psi all around, the fronts are begining to show excessive center wear. I dropped them back down to 35, the rears are fine might even bump them to 50 and see what happens, not that there is much weight back there.
Tires are GY Wrangler 235-75-R15, At first I was impressed but after 15k miles they don't grip so well in the wet anymore and are a bit soft, like they belong on a car or small SUV not a FS truck.
Old 10-30-2009, 01:01 PM   #2 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
I had that on my michelins. When i let them down, the uneven wear didn't go away so i guess the steel wires were forced into a certain shape when overinflated from new. I have since read here somewhere that, if overinflated from new, tires may wear in the centre due to incorrect bedding in of the steel wires in the tire. This appears to not happen if they are run at normal pressures for a while (not long i hope) and then overinflated.
When i get my next tires i'll leave them at 35psi for the first week or so. Then i'll go the whole hog on them!
I know we mostly say there is no uneven wear but there may be cases where this is not the case. Anyway, they'd wear unevenly at the reccommended pressures too and that's not considered a problem is it??!!
ollie
Old 10-30-2009, 01:05 PM   #3 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
ollie
I believe the last information I got from an AX club member was to street drive the new tires for 1,000 -2,000 miles before over inflating, so they don't have the issues with cord bedding.
That, of course, is based on their experience, and no real scientific testing.
Old 10-30-2009, 03:07 PM   #4 (permalink)
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
Your wear will not even out unless you run underinflated. The rubber in lthe center is already gone so if you just even out the wear the centers will still have more wear and wear out first.
Old 10-30-2009, 06:13 PM   #5 (permalink)
My tires are a bit wider than the typical HM'ers cars tires
I kept them at 35 for the first 8k miles or so. I do rotate them with every 5k miles.
I just need to take corners faster to wear the edges down to match the center But since I started HMing My speeds have gone down a lot. guess I'm stuck.
Old 10-30-2009, 08:27 PM   #6 (permalink)
Steve - '92 Festiva
Just cuz your speeds have gone down doesn't mean you can't take corners faster. I blame my high-speed cornering on hypermiling...
I take corners at 60 that most people won't take at 40, and I do it in a mini-van with over inflated tires. I also have high-speed training and experience on my side, so I wouldn't expect anyone else to do it, but that doesn't stop me. As long as I'm not violating the speed limit, the yellow "cautionary" signs don't mean anything to me on my normal routes.
Old 10-30-2009, 08:40 PM   #7 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
I am dropping my air pressure down to 35, after I skidded for about 50 feet today.
Old 10-30-2009, 08:44 PM   #8 (permalink)
Steve - '92 Festiva
I can't convince you otherwise, I'm sure, but can you conclusively say that overinflated tires are the reason you slid?
I don't want it to seem like I'm saying you're wrong for lowering your pressure (apparently, that's what people read into my posts ) but I'm just asking for the sake of knowing whether you checked for a repeatable result, or just assumed that was the reason.
Old 10-30-2009, 09:02 PM   #9 (permalink)
Over inflation is a dicey thing, if you REALLY want to do it buy 16" rims, most 16 inch tires are 8 or ten ply in LT sizes and can take the pressure. The infamous Ford tire debacle was a combination of wrong tire for the job and too much pressure.
Dave
If it has a motor its worth playing with.......
Old 10-30-2009, 10:37 PM   #10 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I thought the separations were partly due to underinflated tires?
Who besides us has overinflated tires?
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 5 10-09-2009 11:09 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
