Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-01-2014, 01:53 PM   #1 (permalink)
Had to hook up the mobile generator (Prius) this morning
I had to lug out the mobile generator aka the Prius this morning to pump 2" of water out of my basement after a pretty big storm went through and took out power for ~13 hours. It was surprisingly easy to rig up quickly, and worked out quite well.
Full story: Had to hook up the mobile generator (Prius) this morning - EcoRenovator
Old 07-01-2014, 04:25 PM   #2 (permalink)
I thought you totaled your "generator"? Isnt this the "wifes" "generator"?
Old 07-01-2014, 04:32 PM   #3 (permalink)
When I totaled the last Prius, I replaced it with this Prius. Our cars are our cars. We don't really have a mine and hers. We just drive whatever makes the most sense. She has the longer commute now, so she drives it.
Old 07-01-2014, 07:47 PM   #4 (permalink)
If I own a home with a basement, I dont think you can have enough devices to pump water out. Id make sure to have a few including a gas powered one and a big deep cycle battery with a trickle charger and inverter.
My sidekick has a 105 amp alt, but my insight is 70 amps. Puts a limit on the largest inverter you can use.
Old 07-02-2014, 10:37 PM   #5 (permalink)
Gotta agree with that. If I were living in a house with a basement (and I still consider to do that eventually), at least one engine-driven water pump for emergencies would be a must.
BTW eventually repurposing the drive system of a wrecked Prius as a gen-set might not be a bad idea at all
Cobb (07-03-2014)
Old 07-03-2014, 06:48 PM   #6 (permalink)
Yeah, I had hoped Dax re purposed his/hers wrecked prius to a 220 volt generator with the mains in the rear ready to back feed a transfer box to his home. There was talks about doing something with an insight hacking the 3 cables from the ima rotor and govern the engine at like 1800 rpms.
