Old 08-10-2009, 01:17 AM   #1 (permalink)
pgfpro's Avatar
Happy with my first base tune.
I had a great day today.
My wife and I decided to go for a nice drive and get a base fuel-log.
I spent about 8 hours worth of tuning my city and freeway driving in the last month. So I decided its time to see where were at. (Neptune engine management)
After a 144mile trip with about 15 miles of it in town we got 44.5mpg.
This was with a temperature of 81*F and about a 85*F increase as the day went on.
I'm running a 15.5 A/F ratio at 65 mph. My next plan is to lean it out a little more to around 16.5. Plus I'm going to add a little more timing to help with the power.
How lean are you guys with Honda engines running at freeway speed?
Edit I forgot to mention that this was on 10%ethanol premium pump fuel.
Also this is a turbo-charge engine with a 8.5 compression ratio.
Old 08-10-2009, 01:37 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I run about 22:1 on the highway
d15z1 though!
Nice numbers
Old 08-10-2009, 01:52 AM   #3 (permalink)
pgfpro's Avatar
d15z1 though!
Nice numbers
This is just what I was looking for. I guess I need to lean on it a bit
Old 08-10-2009, 01:57 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
You're not gonna get those numbers without the honda's lean-burn tech though
I think any higher than 16.5:1 and you'll probably see reduced FE
Old 08-10-2009, 02:07 AM   #5 (permalink)
pgfpro's Avatar
I'm sure your right this is all new to me as far as saving fuel. When it comes to making power and using a ton of fuel... well I can do that really well.
My goal is to get 50mpg freeway.So hopefully I can get close? Thanks for the input!!! Heres a pic of the sol.
Old 08-10-2009, 02:14 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yep. If I were you I would make a neat little kamm for the del sol out of plexiglass. That aero alone will help a bunch
Old 08-10-2009, 02:32 AM   #7 (permalink)
pgfpro's Avatar
Hmmm....
Would you take it all the way back to the end of the deck lid or just follow the side sail panels??
Old 08-10-2009, 02:34 AM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
Probably all the way back as a full bubble, if the airflow would stay attached.
Old 08-10-2009, 10:09 AM   #9 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Taking off the mudflaps and putting on some smooth caps wouldn't hurt...
Old 08-10-2009, 10:40 AM   #10 (permalink)
pgfpro's Avatar
I'm going to get some card-board and start making a template for the Kamm back.
I will also be removing the mud flaps and try to find some of those 50' style hub caps.
Thanks again for all your guy's help.
2009 Prius Base - $19k Matt Herring Hybrids 283 12-29-2009 03:12 PM
vx owner needs help with tune up!! backsidesnap DIY / How-to 8 02-25-2009 09:49 AM
TUNE IN TO NPR RIGHT NOW! Science Friday Big3 Bailout and Electric cars bennelson EcoModding Central 3 11-21-2008 02:35 PM
90 CRX HF.. is $160-180 a fair price for a tune up dylanu EcoModding Central 12 10-11-2008 12:36 PM
Very happy with 3.97 l/100 Km (59.25 MPG) record tank RPM Success Stories 2 07-05-2008 02:01 PM
