Old 11-12-2009, 06:42 AM   #11 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by roflwaffle View Post
Have you tested the donuts RR in order to see if there's a significant difference between them and a small LRR tire? Besides, at best you could pick up a few mpg at 70-75mph if you cut the rolling resistance in half compared to whatever is on there now. If you cut the drag coefficient in half like basjoos did, you'll gain 20+mpg at 70-75mph, and there won't be any worries about undesirable operation.
Based on what I know about tires, using donuts to improve fuel economy is futile. There is no attempt by the tire manufacturer to control RR - or wear or traction or ride or durability. It's all about cheap. They use substandard materials in these tires because they only need to go 50 miles at 50 mph.
You'd be further ahead (and a whole lot safer) selecting tires where the feature IS RR!
The Following User Says Thank You to CapriRacer For This Useful Post:
Christ (11-12-2009)
Old 11-12-2009, 02:51 PM   #12 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
We should sticky your post meng!
Old 11-12-2009, 07:29 PM   #13 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I have a very old set of 12" 125 donuts on the front of my C-car (used to be all 4 wheels), so long as the car is VERY light the tires wear OK but only have as much grip as a half worn summer tread. One tire on the c-car has a weight capacity of about 800lbs more than the entire car weighs.
Donuts do have a very low rolling resistance, at least mine do but that is because they are like driving on a hard rubber tire, the inside including under the tread is 3ply with nylon, with all the air let out the tire doesn't compress very far
Old 11-13-2009, 10:05 AM   #14 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by rmay635703 View Post
.......Donuts do have a very low rolling resistance, at least mine do.........
The reason you have good RR is because you are only using 25% of the load carrying capacity. ANY tire has good rolling resistance at that level.
Old 11-13-2009, 12:28 PM   #15 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
There's an echo in here here here here...
Old 11-13-2009, 08:47 PM   #16 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
You hear it too, eh? Eh? EH?
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Interesting story that's hard to find RandomFact314 EcoModding Central 1 06-09-2009 01:08 PM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
