Old 12-24-2009, 03:36 AM   #1 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
SCarlett - '00 SC1
90 day: 35.22 mpg (US)
Has anyone experimented with propane?
I had a thought and I'm gonna throw it out to the EM dogs to see whats left when they chew it up
Has anyone here ever converted a two stroke gasoline engine to propane power? I've got a 1998 Yamaha Vmax two cylinder sled and gasoline and carburetors are a pain in the rear.
~Jimbo
114 lb/ft of economical fury
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
Old 12-24-2009, 07:10 AM   #2 (permalink)
Gas Passer
Burnt's Avatar
Burnt's Cobalt - '09 Cobalt LT XFE
Team Chevy
90 day: 38.66 mpg (US)
I spent 4 years living in mexico, I saw tons of pickups driving around with a propane tank in the back which they used to power the truck instead of gas; propane was cheaper
Old 12-24-2009, 09:36 AM   #3 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
You may think gas is a pain, but in a sled, what if you get it stuck and run out of gas out in the boonies? Whose got a back up tank to give you enough to get back?
Propane might be OK for a road vehicle, but I wouldn't consider it for anything off-road. But that's just me...
Besides in a 2 stroke all your lubrication comes from oil mixed with the fuel. I don't think you're going to find 2 stroke propane oil.
Old 12-24-2009, 06:21 PM   #4 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Accord LX
90 day: 35.57 mpg (US)
dump oil in the cylinder! about 42% oil, and 42% propane, and 16% of whatever you want.. i choose kool aid.
single person car thread
Old 12-28-2009, 02:41 AM   #5 (permalink)
I've also had propane tanks stop out-gassing in the northern Rockies of Montana because it got too cold out.... Had to heat the propane tank to get the furnace to run...
Used gas from the snowmobile to make the heat... :P
Dave
If it has a motor its worth playing with.......
Old 12-28-2009, 02:57 AM   #6 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Some 2 stroke engines have their own oil supply, actually. I'll find one when I get back online to show you, but not all 2 strokes actually have mixed oil and fuel.
(I'm thinking that the ones that don't need to be mixed run on diesel fuel, though... not sure.)
Old 12-28-2009, 05:16 AM   #7 (permalink)
Just because you don't premix the oil into the gas doesn't mean that it's not mixed with the fuel before it's injected into the engine. Snowmobiles don't have a wet sump crankcase. All the lubrication comes from the fuel charge injected into the bottom end, lubricating things there before being pumped into the combustion chamber.
Old 12-28-2009, 09:29 PM   #8 (permalink)
Steve - '92 Festiva
I saw that after posting, when I looked at the motor I was thinking about.
I'm still thinking that there's a dry-sump 2 cycle out there somewhere that doesn't require fuel mixing at all, though.
Old 12-28-2009, 10:35 PM   #9 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I've never seen one, but I think the oiler from a Wankel could be used to inject oil in to the fuel/ air mix.
Totally not sure about that one.
Also remember that Propane is much higher octane and would benefit from higher compression.
6 speed ALH TDI
Old 12-29-2009, 12:28 AM   #10 (permalink)
Custom User Title
Daily Driver - '02 Grand Prix SE
90 day: 18.45 mpg (US)
older snowmachines used the vacuum in the carbs to draw the oil through the intake. Newer machines use direct electric injection. For a project, I would do it. But it will never be practical. I've never seen a propane tank the size of a gasoline tank eek out as many miles, it's always less.
the newest engine bombardier produces has averaged up to 19mpg at about 50-60mph (trail riding). My dad has driven one, along with several other buddies, all who are excellent riders and know how to use the throttle excessively. In deep powder trail-breaking conditions they still managed over 100mpt (miles/tank) on a 600cc, which is much better than the old take it mostly gentle and get 90mpt. I think over the course of a week he averaged 14mpg on that sled. His 800 mountain sled at home hasn't bested 11mpg.
Direct injection is a new thing for snowmachines, but in time it will prove useful gains. 40-50% better average FE is nothing to sneeze at in the offroad/onsnow world.
Need help with propane.... rkcarguy EcoModding Central 19 10-04-2011 12:40 PM
Anyone experimented with a restrictor plate? thefirebuilds EcoModding Central 16 03-18-2010 07:52 PM
Help needed from propane experts! Custom V8 Propane Turbo Performance Setup mikernet EcoModding Central 16 12-01-2009 11:32 AM
Propane or natural-gas conversion kits! blackjackel Fossil Fuel Free 18 10-03-2008 09:01 AM
Can Propane and Gas be combined? trikkonceptz EcoModding Central 11 07-17-2008 10:54 AM
