Old 11-18-2009, 08:00 PM   #1 (permalink)
JackMcCornack's Avatar
Which has lower RR? Large or small diameter tire
All else being equal (I know, I know, all else isn't equal) does a bigger tire OD help or hurt rolling resistance?
Modding MAX, a Kubota-powered classic sports car
http://www.kineticvehicles.com
Old 11-18-2009, 08:23 PM   #2 (permalink)
B2300 - '96 B2300 SE
Big Red - '88 Concours ZG1000
90 day: 54.41 mpg (US)
Zongshen Sierra 200 - '06 Sierra 200 Supermoto
90 day: 82.11 mpg (US)
Well on bicycles anyway, larger diameter wheels reduce rolling friction, so that could be inferred to car tires also. Probably something to do with the weight spread over a longer patch and less or more gradual flex of the tire.
All else being equal...hmmm.
The disadvantage is that more weight is farther from the axle meaning more energy used to spin them up and slow them down and turn them.
Learn and Share your driving and modding skills at the MPG Challenge in Lacey, WA. First Saturday in May!
http://www.ci.lacey.wa.us/city-gover...ve-energy-fair
Old 11-18-2009, 09:51 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Might want to have a peek at this thread. EM's resident tire expert also suggests larger diameter = better.
Wheels (Smaller is better)
Old 11-19-2009, 11:17 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
What isn't clear in the thread mentioned above is that it isn't tire diameter that has the effect on RR.
It's load carrying capacity - which, if you hold everything else the same (which you can't), is what happens when you only increase overall diameter.
Here's an example of the problem:
P205/70R15: To increase the diameter, you'd have to increase the aspect ratio = P205/75R15. That also increases the load carrying capacity - which is a factor for RR.
BUT - the largest factor is the amount of rubber and the rubber compound itself. A different tire can have a much larger effect than a change in tire size (and load carrying capacity!) The problem is the RR doesn't come without a price to pay: traction (especially wet traction) and / or wear.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 09:45 PM
Largest Tire Diameter on a 6th Gen Civic (for lower RPM) UnCivic EcoModding Central 41 12-07-2009 01:41 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
Wheels - Large or Small Diameter? Width? CorollaMaster EcoModding Central 30 05-14-2008 10:33 AM
