Old 01-11-2018, 12:14 PM   #21 (permalink)
Ecostanced
Jdesign's Avatar
ES9 - '03 Honda CIVIC Hybrid
Originally Posted by S Keith View Post
I find that very concerning. Are you 100% certain the battery fan is being driven?
Are you doing the charging with the IPU lid closed or open?
https://www.dropbox.com/s/k9tgm6qvl2...ector.jpg?dl=0
14-6
6-13
13-4
4-12
1-7
7-2
2-8
8-3
3-9
9-10
I didnt get a chance to check the codes yesterday. The car is kind of boxed in at the moment.
I am 100% sure the fan is running and pumping out air. I have both the trunk open and the IPU cover off.
Sadly I did check the voltage again this morning after the car sat since yesterday around noon (approx 20 hours) with no charge or discharge activity and the voltage dropped to from the 169 it was at to 163.
Old 01-11-2018, 12:29 PM   #22 (permalink)
Okay, there's the problem. With the IPU cover off, you have disabled all battery cooling. Your voltage drop was due to the battery getting extremely hot.
The battery cooling system works as follows:
Battery fan blows air into trunk.
This creates low pressure in the IPU bay.
Air is drawn in from the upper deck, down through the battery, through the IPU bay and then out the fan into the trunk.
You have subjected your battery to extreme temperatures. Couple that with extended over-charging, and you have likely induced a large amount of voltage depression into the pack - what you tried to get rid of with your discharge. Hopefully, you haven't done permanent damage.
BEFORE DRIVING THE CAR, I recommend you:
1) discharge pack to 96V
2) install IPU cover
3) charge the shorter of 32 hours OR peak voltage held for 8 hours. Attempt to verify that air is being drawn in through the vents in the upper deck (you should be able to feel/hear it)
4) remove IPU cover
5) repeat 1-3
Old 01-12-2018, 09:59 PM   #23 (permalink)
(crickets chirping)
Old 01-16-2018, 07:50 PM   #24 (permalink)
Ecostanced
Jdesign's Avatar
4) remove IPU cover
5) repeat 1-3
Sorry I didn't get back sooner. Other priority's took place but im back now. I will discharge to 96v and install the cover and recharge. After doing so I will I will check back. Further note, the voltage has been at 163 since we talked last without any change.
Once I do a few cycles I will connect the regular battery and drive it to see if it still throws an IMA code. If so I will check read the codes.
Old 01-16-2018, 08:01 PM   #25 (permalink)
Given the fact that it's been sitting a few days, it would be a very good time to check the tap voltages before you start the discharge.
The Following User Says Thank You to S Keith For This Useful Post:
Jdesign (01-17-2018)
battery, civic, grid charge, hch, rebuild
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
