Old 12-13-2010, 11:51 AM   #1 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
Headliner construction
I am finally building a headliner for the Jeep's hardtop.
I am using cardboard with headliner material on the inside & a layer of aluminum foil for a radiant barrier on the outside. The question I have is which direction should the shiny side be facing, toward the cab or the sky? It is more to keep heat in than out.
Thanks
Don
Old 12-13-2010, 12:54 PM   #2 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
depends on whether you want to keep "them" from beaming thoughts into your head, or keep "them" from reading yours...
my guess is shiny side in.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-13-2010, 07:39 PM   #3 (permalink)
sid
grayranger - '010 Ranger XL 2 door supercab
90 day: 31.09 mpg (US)
The shiny side must face an air space. Otherwise it doesn't do anything. Theoretically, it doesn't matter if the shiny side is facing up or down, as long as it is facing an air space. Practically, dust tends to collect on it if it faces up, which degrades its performance. So down is probably preferred, as long as it faces an air space. It is usually recommended that the air space be at least 0.75 inches deep to get the full performance specified for radiant barriers.
Search "radiant barrier" to confirm this and for more info.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Road construction leads to better mileage (well sort of) wagonman76 Success Stories 1 08-14-2009 09:11 PM
Construction of boat tail, wheel skirts etc. out of PVC and Coroplast KillerGardevoir EcoModding Central 7 05-30-2009 05:33 PM
Airdam / Undertray / Splitter Construction Ideas TimRogers Aerodynamics 12 03-16-2009 10:14 PM
AutoSpeed: lightweight, simple composite construction technique (monocoque + body) MetroMPG EcoModding Central 14 02-17-2009 07:13 PM
Expanding, sprayable foam as an aero construction / shaping material MetroMPG Aerodynamics 9 01-12-2008 12:13 AM
