Old 07-20-2010, 07:27 PM   #81 (permalink)
which lens or mirror is used in that diagram?
Old 07-20-2010, 07:28 PM   #82 (permalink)
'91 CRX - '91 CRX DX
90 day: 34.91 mpg (US)
There's also the issue of readability. The MPGuino's 2x16 character display at winshield distance might require some squinting, or at least more than the kind of glance-down readability that stock instruments such as a speedometer provide. The MPGuino programming deals with this to some degree with it's double-line number font, but there's still room for improvement IMO.
An ideal display wouldn't require glancing at all... It would be big enough and/or simple enough that it could be read in your peripheral vision. Analog needle and bar graph type displays can be read this way, assuming proper placement and sufficient contrast. Honda took an interesting shot at this in the new Insight with the high-mount digital speedo (an inexpensive but perfectly useful feint at a HUD) whose background changes color as an efficiency indicator.
In fact, such an indicator doesn't need to be visual at all. The 'guino could be programmed to make a tiny blip or pop sound from a speaker for every milliliter (or some other arbitrary unit of volume) of fuel dispensed. As fuel consumption goes up, the pops get more rapid, a bit like a geiger counter.
Old 07-20-2010, 07:32 PM   #83 (permalink)
it could shock you electrically the more gas you use too!
Old 07-20-2010, 07:48 PM   #84 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I see the same picture you see, some concave affair by the base of the windshield.
Heads up Display?
Old 11-10-2010, 03:50 AM   #85 (permalink)
Did someone manage to make a successful HUD yet?
Old 11-11-2010, 12:12 AM   #86 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Protege LX
90 day: 39.39 mpg (US)
The Golden Turd - '01 Grand Caravan Sport
90 day: 16.83 mpg (US)
I managed to get a seven segment display running off an iDuino just as a proof of concept...
I put mine on the back burner when I got to fabricating the final display. Too much soldering at the time and just haven't picked it back up =(
Old 12-04-2010, 12:27 PM   #87 (permalink)
EcoModding Jack
My I suggest something I worked on many many years ago.
To display MPG, it really is just a single number, and a single number can be represented as a bar graph. So instead of doing a HUD with digits, just create an LED bargraph that runs along the base of the windshield. With a bargraph that is 3-feet long, you can easily see the differences of a single digit.
My very first electronics project was creating a bargraph for the RPM display on my racecar. It ganged up 80 10-segment led bargraphs together (using LM3914), and displayed an 0-12v analog voltage signal as the bargraph. It was placed at the base of the windshield, and ran from right to left. This placed the spot where you shift right in front of the driver.
It also doubled as the speedometer when not racing, since RPM shows speed at a fixed gear ratio (always in 1:1 3rd gear on highway in my car).
This had never been done before, and still hasn't been done AFAIK. Totally cool seeing the "RMMMM, RMMMM" with the LED jumping to the left along with it.
The bargraphs were too dim in daylight (and too bright at night) so I created a shade for the display, but with todays LEDs this isn't a problem.
You could also use two or three different colors, and display three variables together.
Old 10-14-2011, 10:52 PM   #88 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by meekin View Post
Whoever figures out how to do a HUD. My hat off to you. I would love to have a HUD. I find my eyes creeping more and more to my MPG monitor in town (i have it mounted below my radio). This would be a great safety improvement (at least for me).
I could not agree more. I didn't think much of the HUD option, until I got a safety briefing this week about distracted driving. 4 people in the car, 2 in the back seat w/o belts fastened. Driver using smartphone as GPS, laying in his lap. phone falls on the floor, he bends down to pick up the phone, not realizing he is crossing the median. The car strikes an ambulance, killing 3 of the 4 in the car. I ordered two Arkon SM410 mobile phone holders from Amazon. They have a suction cup, and a vent holder option. A good second to a HUD...
I found this very sobering, because I have used my phone as a GPS several times, laying in the console instead of high on the dash or on the windshield. I then realized I spend a lot of time looking at the MPGuino while I am driving. I am quite interested in this, but lack the technical know-how.
Old 10-15-2011, 11:43 AM   #89 (permalink)
with lots more to do
ecomodded's Avatar
Dusty - '98 Beetle TDI
Diesel
90 day: 62.64 mpg (US)
Originally Posted by dcb View Post
I had to do a quick experiment with a makeup mirror too, and a short extender cable It is promising, it is brighter in real life and the lcd is currently limited to half brightness (and might be pulse overdriven to a brighter appearance). A LED array might not be a bad idea either, but complicated.
I was thinking if you mounted your gauge upside down 'then' reflected it to the windscreen it will/may display the right side up. ?
1998 Beetle tdi
AGR motor with stock K03 turbo
5-speed with fuel pump tuning box
rims and a roof spoiler
Boost gauge
Screw heads? Sean T. Aerodynamics 3 09-24-2008 10:21 PM
Can you change the scanguage display "rate" default to FAST? blackjackel Instrumentation 8 08-27-2008 02:09 PM
Analogue MPG display using an OLED? ecoxantia Instrumentation 2 08-22-2008 08:23 AM
2x16 LCD Display issues/discussion dcb OpenGauge / MPGuino FE computer 29 08-19-2008 07:25 PM
E.O.C. cracking heads? scissorhands EcoModding Central 8 07-12-2008 10:16 PM
