Old 01-11-2008, 12:36 AM   #11 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Probably not - most transmission cases are aluminum...
Old 01-11-2008, 12:39 AM   #12 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
EBH (transmission boost too?)
I'll tell ya -- if it wasn't for the engine block heater plug-in, my tank average in the cold Winter would be about 5 MPG lower. (This is the direct, factory addition).
I too suffer from auto-trans, Arctic inefficiency. The torque converter is VERY hesitant to engage, and it won't upshift lower than 2500 RPM after a cold-soak start.
Since the rad has a built-in tranny-cooler, I assume a quick burst of warm transmission fluid is sent through the system on startup after plugged-in. That's it, I bet.
My guess is that your TC is acting-up in the cold. It can engage and disengage without change in speed, but the engine effort changes. Chrysler trannies are pretty particular to cold. This is followed by foreign brands, and finally by GM (they'll lockup at -40F, 2 miles after startup). Ford? Well, it varies...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 01-11-2008, 12:02 PM   #13 (permalink)
Silver Bullet - '02 Golf TDi
Great resource page, Metro, but it is missing one very effective and inexpensive style of block heater...the adhesive pad heater.
For example: http://www.spiderautomotive.com/oilpanheater.html
I installed three of these on side of the block, dry sump tank and to the bottom of the transaxle of a customer's car, and we were both extremely pleased with the results.
They easily conform to non-flat surfaces, attach to aluminum, plastic, iron, whatever with hi-temp silicone adhesive (usually included)...and they really work well! Start the engine up after 30 minutes of being plugged in and the temp needle was instantly in the green arc. It might need an hour in colder climates.
You don't need a Moroso brand, either. Lots of folks make and sell them. Just do a search on 'adhesive oil pan heater' in your favorite search engine and you will get tons of hits.
Stan
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
Old 01-11-2008, 12:06 PM   #14 (permalink)
Stan - great find. I hadn't seen those before. Thanks for posting.
Old 01-11-2008, 12:07 PM   #15 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
IMO the block heater is very much worth it. I just put one in my Matrix (wife's car) a few weeks ago. She loves that its blowing warm air seconds after pulling out of the driveway. That alone is worth it, but there are numerous benefits.
Old 01-11-2008, 01:12 PM   #16 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 metro 4 dr HB
90 day: 66.44 mpg (US)
I like to do the timer thing with mine so it warms for a few hours before i take off. It really does make a difference in FE. I've been debating getting one for the wife's 08 civic. The dealer installed optional heater is $130 ish installed. I would normally just buy one and do it myself, but her car is so new I'm hesitant .
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 01-11-2008, 02:16 PM   #17 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
In a better world, the EBH and some electrical interior pre-heating could be better integrated. As you exit the vehicle the night before you simply set 7am on a screen and then plug the vehicle in. It could then determine based on block temperature and ano utdoor temperature sensor when to start heating up the vehicle to have everything ready for you at 7am. Totally green comfort and luxury as compared to remote starters.
My EBH gets the coolant temp up to about 30°C (86°F) and after that I'm just wasting electricity so it gets tough trying to figure out how long to set the timer for. That gets you thinking...
Old 01-12-2008, 12:56 AM   #18 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Turtle Check Your Warranty
After you finish your debate and decide to get one, check with your dealer first about DIY additions to the car. Having worked for several different Dealers, (Different brands), they all have their own hangups about WARRANTY. It would probly be worth it in the long run to allow them to install the heater. Then there is no question of warrant-ability.
I would not want to see your warranty toileted because of "Un-Authorized Modifications". S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 01-12-2008, 12:22 PM   #19 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
My car has 200,000 miles on it. I am not concerned about a warranty.
I am not concerned about how pretty it is. I am not concerned about (low-speed) deer collisions.
It is amazingly liberating to not care what other people think.
Also, why not tinker with such a vehicle? I think the block heater on mine is a frost plug one. It came with the car, but I have really never used it. It may even have been factory installed.
On the photo of my car, that is right after I hit a deer. (Those things are crazy! Hard to dodge them!) Soon after that, I replaced the front of the headlight with a piece of plexiglass and lightly sanded it. It looks almost factory original!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-12-2008, 12:28 PM   #20 (permalink)
And itsa "K" car too boot, I may have a headlight around here for you.
What year and model is it? I'll go look see. S.
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
How much fuel does it take to re-start a warm engine? MetroMPG Hypermiling / EcoDriver's Ed 9 08-15-2009 03:31 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Engine efficiency improvement through higher temp thermostat? Lazarus General Efficiency Discussion 13 02-05-2008 12:39 PM
OBD-II / Factory Specific Engine Scanners DrEMHmrk2 Instrumentation 4 01-04-2008 01:49 PM
