Old 07-26-2011, 08:45 AM   #1 (permalink)
Kodak's Avatar
Canyon - '07 Canyon 2wd regular cab
90 day: 24.83 mpg (US)
Heat gun tips
Hi all,
I have two aero mods pending for the summer: a front air dam and fog light covers. Both will require the use of a heat gun, which I still need to buy or possibly rent. Never used one before as far as I can recall.
Does anyone have any tips for using a heat gun?
I need to mold PVC sheeting to fit the rounded edges of my air dam, and lexan to fit the slight convex of the lights.
Are any other tools required outside of thick leather gloves to avoid burns?
I plan on making a template out of cardboard or poster board for both projects. Will this be enough to match the angles with precision?
Much obliged to any advice, and I will post pics if I complete these projects.
EcoDriving: Turning more fuel into usable forward motion.
Old 07-26-2011, 09:45 PM   #2 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
I have one. They are very usefull.
NOTE: they get VERY hot. Do not apply for long periods.
I`would use polycarbanate instaed of lexan. Less brittle, more forgiving
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-26-2011, 09:58 PM   #3 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
Lexan is polycarbonate. Polycarbonate could be Lexan, Makrolon, or other trade names.
Acrylic, such as Plexiglas, is easier to form than polycarbonate. Polycarbonate should be baked in an oven at 200 deg F for at least an hour to remove dissolved moisture. Otherwise, it may form bubbles when you try to heat form it.
Get a heat gun that has at least two heat levels. Continuously variable heat is not necessary. Heat guns are cheap. Just buy one.
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
graydonengineering (08-01-2011), mcrews (08-10-2011)
Old 08-09-2011, 03:54 PM   #4 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
My only advice is to keep the heat moving do not keep it to close to the piece and do not touch the metal part.
I move at the speed of awesome.
