Old 09-18-2008, 09:48 AM   #1 (permalink)
Alero - '00 Alero GL
90 day: 24.82 mpg (US)
Hello from 2000 Alero
Hi, my name is Rob and I drive a 2000 Olds Alero automatic with a V6.
I have been lurking here for about 1 month and bought a scangauge II last week.
I have been trying to increase my mpg by starting slow, anticipating stops, and shifting into neutral going down hill or coming to a stop.
I drive mostly in the city.
A couple of quick questions:
Am I doing any harm to my car by shifting it into neutral (it's an automatic) as I am going down hill, slowing down or coming to a stop?
Also, before I got my scangauge II, I was accelerating off the line as slowly and gently as possible, but the scangauge is showing that is just keeping me a low mpg (below 10mpg) for a long time. Is it better to accelerate a little more aggressively and get the higher mpgs going a little more quickly?
Thanks.
Rob
Old 09-18-2008, 10:14 AM   #2 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
Welcome. Watch the SGII for verification, but getting the auto trans into a high gear more quickly is usually better. Not a tire burning kind of start, just a bit more aggressive. And let up on the gas every time you get to the rpm shift point so the trans can unload and shift.
Old 09-18-2008, 10:47 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Welcome to the site.
bikin' Ed knows his stuff. A slightly more agressive start will be better, just try to avoid real high rpms. I'd also bump up your tire pressure to max sidewall, and even think about using engine off at stoplights if you know your going to be sitting for a while.
Old 09-18-2008, 09:24 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Welcome to the site. As far as coasting goes, I would ask your dealer if the car is able to be towed behind an RV. This will give you the answer you need.
Old 09-19-2008, 01:39 AM   #5 (permalink)
The Move - '99 Move Aero Down Custom XX
90 day: 29.89 mpg (US)
Send a message via AIM to Dust Send a message via Skype™ to Dust
Towed without a dolly. that will tell you if the trans will have problems with the AT pump moving fluid.
Old 09-22-2008, 09:57 AM   #6 (permalink)
Thanks for all of the responses and welcome.
The owner's manual says it can be towed flat up to 65pmh so I guess I should be ok if I stay below that speed while in neutral?
I'm still a little wary of doing as quite a few people say it's a bad idea (on other places on the net) but I am not sure if they know what they are talking about.
I don't want to mess up my transmission but loving seeing my scangauge at 100mpg. I only wish I had a manual transmission so I could really see big numbers.
Thanks again.
Rob
Old 09-22-2008, 11:49 AM   #7 (permalink)
CM400E - '81 CM400E
Keeping the engine in neutral and coasting is fine for an automatic tranny. It will cause a little added wear since you are shifting more, but not that much. Just think how often you shift in city driving. Dropping into neutral here and there is not going to cause a ton more shifting.
The only concern with the flat tow issue is engine off coasting because auto trannies usually use pumps powered by the engine to keep them lubricated. Your doesn't have this reliance, so you should be fine (up to 65 mph).
Old 09-23-2008, 04:16 PM   #8 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 20.27 mpg (US)
Those are nice cars
My driver's ed car was a mid-2000s Alero Sedan.
Old 09-23-2008, 09:13 PM   #9 (permalink)
Carbon based lifeform
dentprone's Avatar
Green Rocket - '01 Forester
Clifford - '76 M880
RuhRoh - '94 Metro
Welcome, 2000Alero
Those cars have one heck of a motor, I have heard. They are capable of relatively high RPM if I remember correctly.
-Chuck
Watching paint dry?
Check out my blog.......
http://www.mobiblog2500.blogspot.com
Old 09-23-2008, 11:30 PM   #10 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
I have a similar powertrain, and noticed the same things as you. Nearly every stop or change in direction on my way to work is up a hill afterwards. Before the mpguino I used to crawl up the hills when nobody was behind me, then after the mpguino I realized how much more mpg I was losing overall in the 25 mile trip. I was getting similar numbers as you as well. Same goes for coming from even a level stop. Learn your shift points. Push a little harder to get it in high gear quicker then let off like biker ED said and youll be better off. Even when starting out cold, you wont have a TCC till it reaches operating temp, but at least get it into OD and thatll help too. Assuming the speed limit in your area will let you do that of course.
Winter daily driver, parked most days right now
Summer daily driver
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
Will smooth hubcaps fit my 2000 Civic wheels? swoody Aerodynamics 15 09-06-2008 12:51 PM
Not mine, CL: 2000 Chev S-10 TDI Diesel 4X4 (graymarket vehicle) - $6000 Red For Sale 0 08-10-2008 11:17 PM
Bought a 2000 Carvan 2 weeks ago, filled up for the first time. EXTREMELY bad mpg. Warhawk626 EcoModding Central 17 06-12-2008 01:19 PM
Fuel tank size on 2000 Sunfire? bennelson EcoModding Central 10 02-10-2008 09:34 PM
