Old 03-06-2010, 12:33 PM   #1 (permalink)
Hello... again.
Hi everyone,
This is the second time introducing myself.. The first time seems to have gone into the ether some how... Hopefully this time it will work.
First off, I should say, I'm not an eco-modder by the traditional definition (my car has absolutely no mods, and I only try to drive the speed limit to save gas). However, I am a huge proponent of electric vehicles and therefore, I think I have a lot of the same interests when it comes to efficiency of transportation. I joined ecomodder to meet like minded people with similar interests.
My day job is as a computer programmer and I have a small company called Xenopi Studios. For the past 10 years, we've been doing entertainment software (read: videogames) but I've always had an interest in alternative transportation (my education is Aerospace Engineering from Univ. of Michigan). It wasn't until recently though, that I decided to combine my day job (computer tech.) with my hobby (electric vehicles).
In case you're interested, we're working on two projects related to electric vehicles at Xenopi. One is the SPARC XEV, an electric super-efficient highway capable commuter, and the other is the xenoDisplay, which is a unique combination of software and hardware that allows people to use iPhones/iPod Touches as wireless digital displays for their electric vehicles. If you're curious, you can check out the xenopi website, which has more information. It's still pretty sparse, but I hope to be regularly updating it as both projects progress.
I'm looking forward to meeting and getting to know everyone.
Cheers!
Eric
Old 03-06-2010, 01:35 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
chaster -
Welcome to EM! You made me look :
The SPARC – XEV Project - Xenopi Studios
SPARC XEV Current Configuration Technical Data
Configuration: 2F3T Tandem
Max # Passengers: 2
Overall Length: ~114″
Wheelbase: ~90″
Track Width: ~44″
Suspension: Independent Coil-over gas shocks on all 3 wheels.
Braking: multi-pot Hydraulic Disc brakes on all 3 wheels
Frame Construction: Aircraft grade high strength Aluminum Tube with high strength Steel for critical components. Integrated roll bar.
Body Construction: Composite with reinforced side impact beams.
Vehicle Total Weight (projected): ~700 lbs.
Target Cd: < 0.2
Drive Motor: AC-31 Induction with Regen running at 72V.
Motor Controller: Curtis AC Controller
Prototype Battery Pack (~1/2 maximum capacity): 7.2kWH LiFePO4
Battery Monitoring System (BMS): eLithion Lithiumate
Charger: DeltaQ 72V 1KW LiFePO4 onboard charger.
CarloSW2
American Solar Energy Society
Old 03-06-2010, 11:49 PM   #3 (permalink)
Thanks CarloSW2, I'm looking forward to learning from the broad store of knowledge here. (also hopefully looking to get some inspiration and moral support too =)
Cheers,
Eric
Old 03-07-2010, 11:52 AM   #4 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Welcome aboard. "2F 3T" sounds like a tilting vehicle. I've been on the tilters list for years, and am not really happy with any of the schemes to control tilt, although the Carver didn't seem to generate any complaints about its response.
Old 03-07-2010, 12:51 PM   #5 (permalink)
5speed5's Avatar
TBSS - '08 Trailblazer SS 2WD
90 day: 18.87 mpg (US)
Wife's car - '09 Impala SS
90 day: 22.96 mpg (US)
Big Blue Hippo - '06 HHR 2LT
90 day: 42.79 mpg (US)
Welcome! The SPARC looks like a great project. When do you expect to have a
prototype vehicle?
Daily driver:
Old 03-07-2010, 02:16 PM   #6 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
SCarlett - '00 SC1
90 day: 35.22 mpg (US)
Curtis AC drive and DeltaQ chargers are both very solid products, as far as I can tell. good choice.
~Jimbo
Mechanic, The Electric Vehicle Store
114 lb/ft of economical fury
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
Old 03-07-2010, 02:42 PM   #7 (permalink)
Yes, it is designed as a tilter. However, the design is such that it also can be configured in a non-tilting setup (which it is right now).
If you've been on the yahoo tilter group list for a long time, then you are probably familiar with FTC. Our tilt system design uses a combination of FTC and our own "special sauce" which I refer to as "PHACS".. I'll do a write up on the tilt technology sometime down the road. (gadzooks keeping up a website is a lot of work!).
Eric
Old 03-07-2010, 02:46 PM   #8 (permalink)
prototype vehicle?
Thanks for the welcome. =)
We are targeting summer for a drivable skeleton (i.e. no fairing) in the non-tilting configuration. Then work will focus on the FTC/PHACS mechanism implementation and testing (it only exists in design/simulation form right now). Once that's done, we'll focus on the fun stuff (bodywork and aero optimizations). It will be a long project. Of course, it's BEEN a long project already, so that's okay. =)
Eric
Old 03-07-2010, 02:49 PM   #9 (permalink)
~Jimbo
Yeah, while the SPARC *is* an "Experimental" EV, it is also meant to (eventually) be my daily driver (replacing my 2001 Maxima), so it needs to have quality, dependable components.
Eric
Old 03-07-2010, 04:11 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
chaster -
Eric
Ha ha, when a woman asks you how it tilts, you can say "Just the PHACS, Maam".
CarloSW2
