Old 10-21-2015, 02:00 PM   #1 (permalink)
DieselQuattro - '02 Audi A6 2,5TDI quattro
90 day: 33 mpg (US)
Audi A3 tdi - '01 AUDI A3
90 day: 49.85 mpg (US)
Mercedes ML - '04 Mercedes ML 270 CDI
TDI - Race - '07 Audi A6 Avant Quattro
90 day: 33.11 mpg (US)
Hello from Sweden!
Hi everyone.
I am not new to Eco tune your car or trying to drive fuel efficient ...
I found out of this forum by recommendations on a Swedish ethanol forum. With E85 in your fuel tank you maybe more concerned about fuel consumption because the fact it has about 30% less energy per liter than regular gas.
I have several old cars and because of the tax laws in Sweden diesels aren't that economic if you don't drive a lot. My recent commuter car and off course hobby and project car is my Audi, a -96 A4 FWD with 1,8 liter turbocharged engine. Stock power is 150hp.
Naturally I have done some modifications sutch as converted the engine for E85 104 octan ethanol fuel. The car runs smooth an good without any sign of hammering, pinging or misfire. But I have some cold start problems. At temperatures of about 15 deg C or lower I have problems starting cold. Proberbly because the cold start program in Ecu is to lean for ethanol. If I floor the pedal when starting things get easier but not easy.
I have replaced th injectors with bigger and now recently replaced exhaust manifold and turbo. Just now in testing and trimming in state. I hade som boost problems with the new turbo so I think I had a quite lean run before adjusting boost pressure. I'm now running at 0.9bar (13psi) for safe reason. 0.7bar (10psi) is stock setting.
I plan to delete viscofan and power steering and to do some aero mods.
Best regards
Z
Old 10-22-2015, 08:25 AM   #2 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Hi Zovix,
I assume you've already added block, coolant and/or transmission heaters? I know starting ethanol is tough, so warming things up beforehand can't hurt.
Or is your drive long enough to even make it worth the trouble?
Old 10-22-2015, 02:38 PM   #3 (permalink)
90 day: 33 mpg (US)
Originally Posted by elhigh View Post
Hi Zovix,
No actually I don't have any heaters just yet. I hade to dismount the coolant heater due to leakage. Naturally it will be replaced. I plan for fuel preheating.
I have 60km one way trip to work so I spend a lot of time in my car, also I live in a little town so I have a 20min (18km) ride just to go shopping. I try to plan to shop on my way home for work but sometimes I'm just to tired so I drive straight home.
I am interested of learning more about transmission heaters.
/Z
Old 10-22-2015, 03:21 PM   #4 (permalink)
Welcome to the site. It sounds like a fun project you have there. We'd love to hear more about it as you progress.
Old 10-23-2015, 08:21 AM   #5 (permalink)
Master Novice
elhigh's Avatar
/Z
Oh, man. We know how that goes.
I reckon there are all manner of engine and tranny heaters available for snowy Sweden. Shop around.
Old 10-23-2015, 02:56 PM   #6 (permalink)
90 day: 33 mpg (US)
O actually it's not that snowy for now. I live in the region around Stockholm and for now we actually have un usual warm with temperatures well above zero degrees Celsius. But things can change quickly.
Old 11-22-2015, 12:55 PM   #7 (permalink)
Welcome!
Cold just start here in Portugal and mpg already go way down...
A grill block and heaters are mandatory to good mpg in Sweden I think...
Old 11-23-2015, 04:38 AM   #8 (permalink)
It became more usual in Brazilian flexfuel cars since 2009. Since the first Brazilian car featuring fuel pre-heating was a Volkswagen, it might not be so hard for you to find parts to retrofit into your Audi
