Go Back   EcoModder Forum > AltModding > Saving@Home
Old 05-03-2008, 01:11 PM   #1 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Unhappy HELP: Any HVAC Experts?
I have a bit of a problem...
My heat-pump compressor won't activate (it's temperate enough this weekend to open the windows, but a test of the system revealed some trouble).
Symptoms:
  • A/C will not engage; thermostat does not indicate operation at setpoint
  • Heat will not engage, but thermostat indicates that it is running
  • Aux-Heat (Gas) functions properly
  • System blower fan is functional
What I've checked:
  • Power to the compressor
  • All wiring is intact at the 'Stat, Furnace/Blower, and Compressor
  • Circuit breakers OK
  • System status LED at furnace/blower indicates "Normal"
  • No trouble codes at the 'Stat
  • Outdoor temp is functional from the 'Stat display
We've had some pretty bad storms with lots of lightning lately. We usually either get struck nearby, or take a surge from a strike. My guess is a bad relay somewhere, which is beyond my repair.
Any thoughts? Someone will have to come out Monday if I can get it fixed.
Thanks...
-RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 05-03-2008, 03:21 PM   #2 (permalink)
RH77's Avatar
Nevermind
Nevermind. It just started working again
Maybe there's a loose connection, or it's temp related.
RH77
EF5 / 22-May-2011
_
_
Old 08-22-2008, 05:37 PM   #3 (permalink)
I don't know if you get fire ants up there,but we have 'em in Texas and they love relays.They get inside and die,then when the T-stat calls for cooling the contacts can't make and compressor won't kick in.Fun! Compressed air will purge out the dead bodies and restore operation.It's a lone-star thing!
Old 09-01-2008, 08:50 AM   #4 (permalink)
Sorry so long getting back,write to me anytime
I always get on the sign about gas mileage.Today I was looking at other topics.So I hope that I can help,.THX
Old 09-01-2008, 12:44 PM   #5 (permalink)
RH77's Avatar
Sorry, this thread kinda merged with another and I forgot to update it...
The system just started working on its own the next day...
But, about a month later, lightning blew out the capacitor and a technician replaced it (after a few uncomfortable nights -- of course it happened on a Friday )
Now the system is running great. No Fire Ants up here, thankfully
RH777
EF5 / 22-May-2011
_
_
UNESCO experts say worldwide farming techniques must change Frank Lee The Lounge 2 04-15-2008 11:14 PM
