Old 11-24-2008, 11:55 PM   #1 (permalink)
Send a message via AIM to Zaq_b
HELP Aveo Steering Pump Removal !
I am sorry to say I own an Aveo. I was wondering if there were any made without steering pumps or if there is a belt that would be smaller that I could use. I just figured its a pretty small and light car. Who needs power steering ? I drove my neon without it for a year and a half. Well Thanks for reading.
ZAQ
Old 11-25-2008, 12:45 AM   #2 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Welcome,
Interesting question, what is best way to decommission the system , just loop the oil lines or what?
Old 11-25-2008, 08:23 AM   #3 (permalink)
well that end of it yeah I looped them on the neon. Then there was a seprate belt for the power steering. So, I just took that off along with the extra lines and pump. With the aveo however the powersteering belt is connected to the alternator. So this will not work out too well. Unless I get a shorter belt. I was just wondering if anyone knew of what belts would work.
Electric water pump Gregte DIY / How-to 84 02-10-2012 12:26 PM
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 08:53 AM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 51 10-03-2010 09:24 PM
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 0 10-25-2008 01:09 PM
"underdrive" power steering pump? gascort EcoModding Central 9 08-19-2008 10:36 PM
