Old 12-14-2015, 06:02 PM   #1 (permalink)
Gen2 Prius - '08 Toyota Prius
90 day: 98.01 mpg (US)
2008 Gen 2 Prius Plug-in Conversion
My project to convert my 2008 Prius to make it Plug-in is now complete.
I used the 10KW kit from Plug-in Supply without the charger, batteries and BMS. The latter I purchased from within in Australia to save freight costs.
I used 76 Winston 40Ah prismatic cells in a custom steel frame.
The way I did this conversion left most of the trunk space available for strollers and car seats etc for my wife to cart the grand kids around.
At the moment we are getting around 2.4 Litres per 100Km (98MPG(US) or 118MPG IMP)) and very happy with this long term average over 1000's of km.
By charging each night we are now getting around 2000km to a tank of petrol.
In fact the other day I filled up when the petrol gauge was down to 3 bars... after filling I found that it only took 35 Litres so there was 10 Litres left which would have allowed us to go at least another 400km !
Please see the Blog on my website: www.evplus.com.au
I'll put some photos up here soon...
Eric
Downunder
The Following 5 Users Say Thank You to evric For This Useful Post:
Insight for life (12-20-2015), LegalShieldNden (12-19-2019), NeilBlanchard (12-18-2015), oldtamiyaphile (12-18-2015), Vman455 (12-14-2015)
Old 12-14-2015, 10:57 PM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Wow! Very nicely done; I like that battery layout.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
evric (12-15-2015)
Old 12-18-2015, 07:20 AM   #3 (permalink)
This photo shows the layout of the 76 cells in the back of the Prius...
The Following 3 Users Say Thank You to evric For This Useful Post:
mikeyjd (04-08-2018), NeilBlanchard (12-18-2015), RedDevil (12-20-2015)
Old 12-18-2015, 07:24 AM   #4 (permalink)
This is a closup of how the cells are held down.
The threaded rod are welded to the base of the battery frame and the top nut/washer (silver soldered) combination (eventually covered with felt) supports the clear poly-carbonate cover.
In the final production, instead of the nut and split washer combination, I used Nyloc nuts (a special nut with a nylon insert crimped in), these offer great resistance against vibrating loose
Checkout the blog for more photos: www.evplus.com.au/evplus_blog.htm
The Following User Says Thank You to evric For This Useful Post:
Old 12-19-2015, 09:37 AM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I bought my Prius with the intent of doing a plug in conversion, but it only costs five cents/ km in petrol (best case EV's quote 3c/km), so based on your 50/50 petrol/electric usage, the monetary saving is in the order of one cent/ km.
If the conversion cost was a modest $3,000, the pay back would take 300,000km.
Sad but true
Old 12-19-2015, 04:39 PM   #6 (permalink)
Hi Oldtami...
Thank you for your comments. Where did you get the 50/50 petrol/electric usage figure from? (hopefully not from my website)
That figure would be correct for the standard Prius. My conversion now would be more like 25/75 petrol/electric.
I worked out that even with a total conversion cost of around $7,000 (including 76 LiFePO4 cells) the payback would be around 270,000Km.
In the meantime I am enjoying a very quiet driving experience for most of the time... and less trips to the smelly old petrol station.
Eric
Old 12-19-2015, 08:03 PM   #7 (permalink)
Team Turbocharged!
Pickups
The stock Prius might use it's electric motors 50% of the time, but 100% of that energy came from petrol. Compared to my car (and most other G2 models), you've halved your petrol consumption, so it's safe to assume that half of your car's energy now comes from the grid.
If electricity is free, then your fuel costs have come down to 2.5c/ km. In which case the payback would be around 270,000km. But electricity has a cost too (even if you have solar panels - you probably do- and produce excess power you'll get money back from the electricity supplier).
I've calculated around 4c/km (as have others) is the cost to fuel a Nissan Leaf. So if you run 50% on EV at 4c/km and 50% on petrol at 5c/km. You're only saving 0.5c/km.
That's a 1.4million km payback
3c/km for EV power is the best case scenario if you live where electricity is cheap or have a super efficient EV.
The only way I can see myself doing the plug in conversion now is if I did something like a 2kWh conversion, enough for ~10km of range, that would be enough for 100% EV usage on 95% of my Prius trips. So I probably use around one tank of petrol a year, but still, I'd only be saving 1c/km.
I realize that money saving isn't really the point of a project like this, but it still has to be considered. Just as a comparison I'm contemplating swapping the 4.0l I6 in my Jeep for a 6.2l LS3. People who've done this swap have reported a 2l/100km improvement in economy (going from my current 12 down to 9.5l/100km). That's a 2.7c/km saving but still 370,000km until payback...
Old 12-19-2015, 08:28 PM   #8 (permalink)
I don't really want to keep this fruitless discussion continuing, but I would just like to say that the long term average of 2.5 Litres / 100km consists of driving which consists of much hill work and high speed driving(by my wife, most of the time). Both of these types of driving are not suited to using the Prius in 100% electric mode. I can drive it 100% electric (and I do) around the metro area (on the flat and only up to 60km/hr) for distance of around 75km... and loving it.
Over and out.
Eric
Old 12-20-2015, 04:24 AM   #9 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Very well done. I wish something like this was available for the insight, I can imagine 200+mpg averages would be doable. Depending on the commute distance of course.
The Following User Says Thank You to Baltothewolf For This Useful Post:
evric (12-20-2015)
Old 12-20-2015, 08:20 AM   #10 (permalink)
Great looking conversion! Thanks for sharing. I like how the pack doesn't intrude into the normal usable space.
The Following User Says Thank You to Daox For This Useful Post:
evric (03-24-2018)
2008, gen2, plug-in, prius, toyota
