Old 01-07-2011, 07:15 AM   #51 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Originally Posted by AeroModder View Post
The problem here is that article is for VGs used on airplane wings. The VGs are placed closer to the leading edge on wings, where VGs on cars are on the trailing edge.
Their purpose is the same though : keeping the airflow on the surface, rather than having it separating.
On aircraft, you'll often see VG in front of control surfaces to improve / restore their effectiveness.
Surely they add drag, but you gain from the air not separating.
The trick is to gain more than you lose ... I'm off to buy some lottery tickets
Lifetime fuel consumption :
Old 01-07-2011, 10:32 AM   #52 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
Quick side question. Is vortex generator shape/looks protected by patents etc?
So can I made my own tool and do my own copy version etc...
I also changed my SGII display to MPG when I was in 3 l/100km category. Usually that 3 liters were there all the time, when value moved 0.1L I did not notice no difference in my driving etc. With MPG on display changes are constant when you are doing P&G specially under 100 mpg after that the range is again rough.
www.tuneko.com
Less drag = Less fuel
Old 01-07-2011, 11:09 AM   #53 (permalink)
AeroModder's Avatar
Darwin - '96 Aspire 4 door
Team Ford
90 day: 44.82 mpg (US)
Tuft tested the Airtabs on my Tempo. No difference in the movement of the tufts from the delta VGs, except that they seem a bit tighter (probably because the airtabs are further upstream). Both sets of VGs produce the counter-rotating vorticy shape on the rear glass. This could be from the way the rear end is shaped, though. I'm going to try adding small fences to detach airflow from the sides, so it doesn't try to stay attached and curl onto the rear glass.
The problem with positioning the airtabs is that they're larger and stiffer, and won't conform to curves as easy as the smaller delta VGs. This makes placement much more difficult.
I thought the pair of counter-rotating vorticies from each VG would straighten the flow, but I was mistaken.
EDIT: Moving the Airtabs back resulted in some unusual flow. The top row of tufts all pointed towards the inside, while all the other pointed towards the outside... The edges still pointed up from a recirculation bubble.
In Reason we Trust
Old 01-07-2011, 01:43 PM   #54 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Note that airtabs are not designed to keep the boundary layer attached to the surface. They are designed to create wake of horizontal vortices that act like a boat tail shape.
Old 01-07-2011, 03:43 PM   #55 (permalink)
AeroModder's Avatar
Team Ford
Ah. No wonder they weren't that good.
In Reason we Trust
Old 01-07-2011, 10:56 PM   #56 (permalink)
yea...I'm THAT guy
SL8Brick's Avatar
I've been using the "Vortekz" fins for over 3yrs and have installed them on 6 different vehicles. I like the fact that the fin kits are well made, can be painted-to-match, and can be installed permanently in a reasonable amount of time. And, yes, I'm not gonna lie to ya'...I like the way they look. But I also think their design appears less 'aerodynamically obtrusive' than some other alternatives. However, I shall not be so bold as to speculate on any potential benefits in my applications because that would be less than scientific.
1999 Audi A6 Avant Quattro - 2.8ltr 30v V6/Automatic - 149k miles
1993 Volvo 240 Wagon - 2.3ltr SOHC/Automatic - 323k miles
Old 01-08-2011, 02:19 AM   #57 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Vekke, I'm pretty sure that Patents & Such can only be acted upon by someone if you try to sell the patented thing and make money off of it. It's not like the police will come & kick down your door if they see you with a copy of something. The individual, or company that owns the patent would have to take legal action against you to get you to quit selling them, so if you just make it for yourself....I'd say you're safe. (**Disclaimer** I could be wrong, not a lawyer myself....so don't go dragging me into some Finnish court if you take my advice and the cops kick down your door after all!)
Old 01-08-2011, 02:21 AM   #58 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Vekke wants to make things to sell, you see.
Old 01-08-2011, 04:08 AM   #59 (permalink)
Vekke's Avatar
Diesel
I have to do my own research on that patent issue but conserning that is no new invention I doupt that is has any valid patents at the moment. Some new parts migth have model protection but even that is hard to get if similar products on the market are many.
www.tuneko.com
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
tuft testing, vortex generators, and God's own wind tunnel jim-frank Aerodynamics 10 06-27-2009 02:48 PM
Aero mod - vortex generators Unforgiven Aerodynamics 4 01-05-2009 12:50 PM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 01:09 PM
vortex generators at rear bumper?? crexcrex Aerodynamics 14 08-22-2008 05:11 PM
