Old 11-03-2009, 12:39 AM   #21 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
nice idea on the foam!!!!
I'm off to the store!
Old 11-03-2009, 02:10 PM   #22 (permalink)
NismoMax80's Avatar
Max - '04 Maxima SE
90 day: 24 mpg (US)
I assume the air is forced in between the grille and hood. I have had no issues with air intake or overheating. But my grille block is not completely sealed. so some air is getting through the top especially at the latch.
I finally got mesh (though it won't match) for my lower grille. not sure how exactly to attach the lower diverter now. Still have not finished my belly pan. Measured but have yet to cut and determine how to attach to my fiberglass bumper.
On my 3rd lower grille piece. 2nd one blew off after a year. This one is taped more securely yet still blew down on a long trip.
I am just hesitant drilling holes, and want it as simple as possible.
Grille will be permanently fixed to lower opening.
Maybe the same for the front of the black coroplast diverter but make the back detachable with the bottom of the radiator, somehow...
Then slide the polycarbonate belly pan over the bumper/under the diverter and attach it to the subframe where the oem belly pan once was located.
I got those screw/tabs from nissan but they break so flipping easy. Will have to remove the belly pan when changing oil.
my current project
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 08:00 AM
MetroMPG.com mailbag: details of 104 mpg fill-up? MetroMPG Hypermiling / EcoDriver's Ed 0 02-18-2008 11:31 AM
