Old 07-09-2011, 02:33 PM   #1 (permalink)
Work Truck - '93 C2500 Silverado
Help with ideas for tow/work vehicle
My current vehicle is an early 90's Chevy 3/4 ton, it pulls double duty as a work vehicle and daily driver. Purchased it the first of the year and averaged 15 mpg. After a few mods and adjustments its average is roughly 20mpg combined, towing/unloaded, city and hwy over the last 6000 miles. So far I've got a warm air intake, plugs, wires, cap and rotor, advanced timing to 4* btc, new injectors and increased fuel pressure, heated 02 sensor, and 3.73 gears and a 4l80E trans. I also have an underdrive pulley set ordered, and 2 small electric fans are on the way also. I'm looking for any tips or ideas on how to try and milk a few more mpg out of the truck, also some creative ideas on changing up my gearing for better economy but still keeping pulling power.
Old 07-09-2011, 02:42 PM   #2 (permalink)
For gearing I was thinking about finding a divorced transfer case and bolting it in behind the transmission and swap the rear end to the highest gears I can find, to allow a low range for towing while keeping a good cruise rpm. Or maybe finding a newer model 6speed auto from a wrecked donor and trying to make that work. Any thoughts
Old 07-20-2011, 09:48 AM   #3 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Electric fans are a good idea.
Going to synthetic 5w-40 Vs. regular 10w-anything has been shown to give about a 3% boost.
The Th400 trans and the 3.73 gears are holding you back big time. You could live with the 3.73 gears and get good milage but it would require a transmission swap.
Old 07-20-2011, 10:40 AM   #4 (permalink)
kir_kenix
kir_kenix's Avatar
1997 Chevy s10 - '97 S10 WT
Pickups
90 day: 27.79 mpg (US)
1997 Ford Escort - '97 Escort LX
Team Ford
A manual trans swap is probably the biggest gainer I can think of without losing the ability to tow. You can always do the other little things like synthetic fluids all around, grill blocks, tire pressure bump, etc to get a little more out of her.
Old 07-20-2011, 11:41 AM   #5 (permalink)
Bruiser - '97 D21 Reg Cab
90 day: 23.43 mpg (US)
Aspire - '95 Aspire Base
If you want to drop alot of money you could get a gearvendors overdrive unit and install it, would help with milage plus give you gear splitting to make towing easier, but those are really expensive. Maybe you could find a used one somewhere...
Retired: Will add the new car once i manage to run a tank of gas through it.
Old 07-20-2011, 12:53 PM   #6 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
If this is a diesel a warm air intake is counter productive. It will hurt power and economy as well as increase pollution (NOX). There are plenty of discussions on this. Your best bet is a cold air intake with some form of ram air induction.
Old 07-20-2011, 01:04 PM   #7 (permalink)
V8 guy
Pickups
Ram air was the first mod I did to my diesel and over all was the best single mod I did.
Old 07-20-2011, 01:20 PM   #8 (permalink)
What about a metro and a trailer? I have a buddy who's done some carpentry work for me and he's dropped off the trailer for a week or two. If you could use your truck only for towing when you had to, that could cut your fuel bill in half or less!
Also a belly pan and some aero wheel covers (if you don't mind getting heckeled by the guys at the jobsite!)
Old 07-20-2011, 01:34 PM   #9 (permalink)
DieselMiser
ConnClark's Avatar
Aren't those words mutually exclusive?
Old 07-20-2011, 01:39 PM   #10 (permalink)
I meant a metro to DD to the trailer. (drop off the trailer with the truck)
