Go Back   EcoModder Forum > AltModding > Saving@Home
Old 11-15-2013, 09:34 PM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
help insulating my sandstone home?solid walls-suggestions needed please
The burd and I have been in this house for just over a year and the heating/insulation could do with some work.
I'm looking for any experiences/advice/suggestions you may have as to how to improve the heat retention in the house
House Description
Walls
Mid Terrace (brick wall in hall between us and 1 neighbour, sandstone wall in front room/kitchen between us and other neighbour)
Front/Rear walls solid Sandstone, approx 20-24" thick
All Walls lined with Plaster
Windows
House is fully Double Glazed
Floors
Front Room- solid wood Floor
Hall- Tiled
Bathroom- Tiled
Kitchen- Tiled
Downstairs has a "crawl space" of approx 3ft underneath it with access
Master Bedroom- Carpeted on floorboards
2nd Bedroom- Carpeted on floorboards
Upstairs has space under of approx 350mm to ceilings of downstairs
Loft
No access apparent-think it's been sealed over-unknown if insulated
2x storage cupboards in the eaves in master bedroom- potential access point
Current Heating system
18yr Old Combi Boiler (holds pressure ok)
timer system separate
NO remote/room Thermostat
Front room and Hall have "neo-classic" radiators (like old church Rads)
Bathroom/kitchen and both bedrooms have double panel Radiators with thermostats on each one
Current heating is set to run for 2hrs in the morning and 2hrs late afternoon.
house starts to get chilly approx 60-90mins after the heating switches off.
We also have big discrepancies in heat throughout the house- Warmest to coldest..
Small Bedroom
Kitchen
Living Room
Master Bedroom
Hall
Bathroom
over to you for suggestions/ideas/ingenious solutions
thanks
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 11-16-2013, 05:24 AM   #2 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Rockwool outside wall insulations batts. Dont know the looks of the house, but best would be to insulete all wall from the outside to awoid problems with damp etc. 100 - 150 mm should ot it.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 11-16-2013, 07:46 AM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Main question : do you plan on staying there for a long while ?
How old is it / when was it last remodelled ?
Mid Terrace
So you're locked in left and right ?
Good starting point - neighbours are good insulators ;-)
So you basically have 2 giant cold- or thermal bridges ...
Sandstone doesn't insulate well.
Depending on composition, it has 2 to 5 times the heat loss compared to brick.
The harder / heavier it is, the worst it is -lighter, softer sandstone traps lots of air.
The only saving grace is its thickness.
It gets worse when it gets wet - but just about everything does.
If you can / are allowed to , have it insulated from the outside.
It also changes the external appearance of the house.
You can do that on the inside, but it eats away at the useful space, and gets expensive quickly as you'd need to redo lots of the interior.
Good, but OTOH, say 1980s double glazing isn't what double glazing is today.
It's also the most expensive to replace.
Bathroom- Tiled
If you ever remodel it, think about ditching the tiles for warmer materials.
Wood. Cork. Even plaster.
I've never understood tiles in bathrooms. They're ice cold.
Get it insulated with 1' of insulation.
Still leaves 2' - plenty to crawl through.
Some companies are even filling the whole lot with PUR / PIR these days
You could insulate that, but you'll have heat losses from ground to first floor anyway. It's not really a loss as they help warm up the bedrooms.
Cork chips or paper could be blown in through a hole rather than ripping out the entire floor or ceiling.
Loft
Heat losses through lofts are massive.
Check it out, get it insulated.
Even if it was insulated years ago, it may well be a good idea to add another layer of better insulation.
Running it at a lower temp is usually more efficient.
Rule of thumb used around here is that when it's about 20 years old, you'll benefit from replacing the heater - the new one pays itself in reduced heating cost.
You can get more efficient radiators these days.
Insulate all visible pipes.
Pipes are inefficient as radiators.
A reflective liner on the wall behind the radiator helps too.
Small Bedroom
Kitchen
Living Room
Master Bedroom
Hall
Bathroom
serial set-up, rather than the current parallel distribution starting off a "common rail" at the heater ?
Old 11-16-2013, 06:49 PM   #4 (permalink)
Team m8
Cheers, but we'd be looking to do Internal insulation- We dont want to change the external appearance of the house
We have a Mortgage, and we're well and truly settled- its pretty much ideal (bar the lack of garage!)
Built circa 1895, last re modelled about 1994 (after being flooded!- We now have a bund built to 8ft round the street now)
Yeah, the sandstone doesnt help at all.
Front sandstone wall has large windows, and rear sandstone wall has French Doors- so not only do we have Sandstone, we have coldpoints also
Insulating on the outside would not be possible- A large part of the appeal of the place is the look of it- I believe you can do internal insulation, and TBH would give us an excuse to get rid of all the magnolia, and get some colour underway
The bathroom is weird- the house originally had an outside toilet- so the bathroom is shoehorned in under the stairs.. the shower tray is built into the crawlspace!
Floor and all walls are tiled- I think getting rid of them would be good from both an aesthetic and insulation point of view. Again, however its solid walls all round, but no space that we can afford to lose
re the double glazing- replacement would be good, but I think there's lower hanging fruit to be picked first (and the savings can bolster the coffers for new windows)
I kind of envision splitting the house into two zones- retain heat downstairs during the day, and retain and improve heating upstairs at night
Yep- hearing you loud and clear re that- I will try to organise access- possibly via a neighbours, or by punching a hole through.
Cant have too much insulation upstairs
Lower temp? would that not only work if we had a thermostat so it could come on/off rather than the current "on for 2hrs" setup?
Replacing Rads and pipe insulation are pretty much the basics i'd be chasing. The front room/hall ones can stay as they help the look and feel of the place
Plus any left over pipe insulation=grill block!
Rad reflecters are worth investigation also!
Thanks everyone
Old 11-17-2013, 05:33 AM   #5 (permalink)
euromodder's Avatar
You might want to look at better insulating windows + glass then.
Might well be worth the effort.
The latest window/door sills have no thermal bridges in them.
Getting it done while insulating the inside walls saves on work and remodelling-hassle ... at a high initial cost though.
Making it a massive heat-sink - quite literally.
I'd get that insulated even before you insulate the crawl space itself.
A box of styrofoam plates or the like around it will do a lot of good.
Getting rid of tiles and replacing them with say cork won't cost any space and insulate better / feel warmer.
Cork is really undervalued, but you can get some really nice finishes these days that don't even look like cork anymore.
It need not have the flattened bottle cork - look anymore
Bank robber style. Sounds rather dramatic.
Surely there must be some easier way to get in ?
There ought to be if the houses were built as separate houses back in the day ... if it was one big house divided in 3 later on, well, anything's possible then.
Exactly ...
Especially when you're not using the space.
Any heat going up there is wasted.
You have thermostats on the rads though.
Give it a try over a more or less stable week or so and compare the amount of gas used / comfort.
Last year I've reduced the water temperature from over 60 C to around 45C, and burned less gas despite a longer harsher winter.
No timers here , no heat storage, just rads with thermostats, late-1980s set-up so it'd be about time to replace the heater even if it's just from an efficiency point of view.
But I don't own the place, so ...
