View Poll Results: Which grill opening shape do you prefer?
Pontiac inspired style 1 33.33%
Circular style 0 0%
Triangular style 0 0%
Oval style 1 33.33%
No opening; because Daox is Da Man. 1 33.33%
Voters: 3. You may not vote on this poll
Old 11-16-2008, 02:30 AM   #1 (permalink)
Shadetree Engineer
Tango Charlie's Avatar
Olivia - '03 Vibe
90 day: 37.26 mpg (US)
Help me decide the shape of my grille block openings!
Now that winter is upon us, I've decided to block off the lower grille opening on my Vibe. Doax has run his through the winter with a complete block, but I'm thinking of providing a small opening, if for no other reason than a little style. I thought it'd be fun to get your input on the shape of the openings.
I don't have photoshop, so you'll have to use your imagination coupled with my grid paper scratchings. Here's a shot of what I'm looking at;
The first candidate is a shape that would echo the Vibes original upper grille opening.
Candidate two is two circles. Like the LoPresti cowling openings on newer aircraft like Mooneys and Pipers.
Candidate three would be triangles.
And candidate four would be a centrally placed oval, like the cowling opening on a Piper Turbo Saratoga. The Vibe has a central post that would be visible. I would probably apply some black tape or paint to help it disappear.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 11-16-2008, 05:00 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I voted pontiac but Tim is also a smart fellow, even if he is from wisconsin.
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 11:24 PM
Best material for grille block? Sean T. EcoModding Central 9 09-09-2008 10:54 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 11:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 3 12-24-2007 10:59 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
