Old 06-06-2008, 01:14 AM   #11 (permalink)
Originally Posted by bennelson View Post
I like the idea of using foam-core. It is pretty easy to cut into nice shapes, including curves, with a sharp razor knife.
Sometimes it can be had cheap, if you find a place throwing some out with beat-up corners or printing on it.
Sandwiching that in fiberglass sounds pretty easy - just a big sculpture project!
And, for this app. it need not be too strong, so you could use "veil ply" fiberglass from SIG, available at hobby shops. This has the weave and thickness of, say, fine silk, so is very smooth and would adhere to the smooth surface of the foam core board. much reducing the need to sand it. For shaping, kerf cut the back side of the foam board and/or maybe heat it and shape it over a mandrel.
fairing, motorcycle, vetter
Electric Motorcycle conversion bennelson Fossil Fuel Free 301 05-25-2012 08:08 AM
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 05:23 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 12:33 AM
