Old 06-28-2017, 07:34 AM   #1 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Brake Specific Fuel Consumption
I am learning (or trying to learn) a whole new science since joining this site. BSFC is one of the many black arts I have come across.
I have been unable to find a BSFC chart for my Honda 1.2 i-DSI engine but I do have a Power and Torque curve for it. I have noticed on the BSFC charts I have studied that the sweet spot for fuel consumption seems to always be just below the peak in the torque curve so is it safe to assume, for a start anyway (until I have my ScanGauge), that on my engine it would be round about 2500 to 3000 rpm?
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 06-28-2017, 08:26 AM   #2 (permalink)
I'd say thats a pretty safe assumption. It seems most engines are usually around that range.
Old 07-02-2017, 10:52 PM   #3 (permalink)
90 day: 40.51 mpg (US)
Peak torque for my engine is at 4500rpm, best BSFC is at 2000rpm.
I get the best economy by cruising with the lowest engine RPM possible at any speed.
Old 07-07-2017, 11:47 PM   #4 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
It's worth noting that there's only a tiny drop off if you fall off the peak island - you can go all the way to ~3750rpm with nearly the same efficiency. OEM's have already tuned our engines to be economical for the majority of real world driving.
An OBD gauge is unlikely to pick up improvements in economy at BSFC, it measures air, not fuel, and is never that accurate.
I had a pre OBD MY2000 Mercedes that had a definite dip in consumption as measured at the injectors at ~2800rpm (80km/h). My non OBD 2010 Proton will get my UT-Comp so we'll see I can pick up a similar drop again.
Old 07-08-2017, 05:05 PM   #5 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Minimum BSFC is almost universally close to maximum load at ~2k-3k rpm.
Brake Specific Fuel Consumption (BSFC) Maps - EcoModder
Old 07-09-2017, 06:11 PM   #6 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I still think 3000 is too high... More than 2500 is not a preference of mine, though I have no choice in first and second gear. I also avoid more than 80% load. Natuarally aspirated 1.6L non-vtec Civic gets 60-70mpg tank averages by driving this way almost ALL the time. You mileage may vary.
