Old 11-22-2008, 09:51 PM   #1 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Help. MPGuino not powering up in car. USB o.k.
I just finished installing my new MPGuino kit from spiffie.org
The installation is pretty easy because the ECU is right under the driver's seat which tilts back out of the way.
Everything is now sorted out except for fine tuning the numbers and building an enclosure.
This is on a 1993 Toyota Previa but I think they are all similar.
ECU is under the drivers seat. Red is the injector wire spliced with a black wire in pinout 12 connector B (top connector on ECU) . Black is the vehicle speed sensor spliced with a purple wire with a white stripe on pinout 9 connector A (bottom connector on ECU).
Found 12v+ unswitched under the dash below the steering column. White wire with red stripe. I grounded to the body.
Any questions?
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 23 11-21-2010 04:32 PM
Alt Car Expo Los Angeles 2008 cfg83 Events & Meet-ups 2 10-14-2008 07:21 PM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 09:46 PM
