Old 06-06-2008, 08:18 AM   #41 (permalink)
BBsGarage's Avatar
BBsRide - '06 Corolla CE
90 day: 31.64 mpg (US)
Plain ole steelies cost about $35-$40 each at a place like the Tire Rack.
Try your local salvage/junk yard. or maybe CL.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 06-14-2008, 05:07 PM   #42 (permalink)
Whitey - '05 corolla LE
90 day: 31.33 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
I did my lower grill block mod, i used vertical strips of white duct tape and taped it all the way down, then I used horizontal strips all the way across the bumper to make it look aesthetically pleasing.
Thanks to cfg83 I also got the "racing disk" aka "moon" hubcaps, that should improve aero slightly.
Here is the original:
Here is my mockup:
Here is my final result:
Again original:
And final:
Last time original:
Aaaand final result:
Old 06-15-2008, 11:50 AM   #43 (permalink)
Very smooth good job!
Old 06-15-2008, 12:12 PM   #44 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Let us know how those partial wheel skirts work out too ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-25-2008, 09:06 PM   #45 (permalink)
Ok, so I'm on vacation and cant sleep.... guess I'll post about future mods...
Soon as I get back from vacation, I'm going to start modding up my corolla again and I'm in need with some opinion on wheel skirt mods, unfortunately, my car body curves under the tire:
Less so from the front:
how do i take this into consideration when skirting my wheel? do I make the skirt flush with the car body?
Old 07-26-2008, 10:07 PM   #46 (permalink)
Alright, I've decided to go ahead and fabricate myself some wheel skirts, I've decided I don't want to do any drilling ANYWHERE, meaning the skirt cage will be clamped to my wheel well.
I need a bendable material that will allow me to bend it so I can clamp it to the inside of the wheel whell and I need to find some sort of really strong clamps to hold the cage on there...
Old 07-26-2008, 10:30 PM   #47 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
blackjackel: go here - DIY: plastic rear wheel skirts (Geo Metro)
There's a pic of my "no drilling" attachment method, using flattened copper pipe to make the brackets which I clamped on to the wheel arch lip.
Old 07-26-2008, 10:48 PM   #48 (permalink)
actually your post is one of the refrences i'm using to try and do this, I gave cfg83 and me and him are going to meet tomorrow and try to make ourselves some skirts... the thing I'm interested in the most is the material used to make the cage to fit the skirt on...
Old 07-27-2008, 10:14 PM   #49 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
blackjackel -
This is the "mini clamp" option I was talking about :
It's a sliding window security lock. It can lock onto material that has a width up to 1/4". If the "key screw" causes interference with the tire, you can replace it with a grub screw. If you use the grub screw, the maximum clearance requirement is about 5/16". However, you need enough clearance for an L-shaped hex-wrench to screw in the grub screw.
If there is still an interference problem, there are other manufacturers of these window security locks that may have smaller dimensions.
CarloSW2
American Solar Energy Society
Old 08-05-2008, 03:59 AM   #50 (permalink)
Alright, well I've met with cfg83 and we spent a whole day working on the skeleton for the wheel covers... Since I had replaced my jack and spare tire with fix-a-flat we couldn't jack my car up (we tried his jack but the bolts on my tire were slightly larger and so we couldn't get the wheel off), drilling was impossible with the wheel on.
We tried the window security lock idea listed above this post, but it wasn't secure enough... it was going loose with a little abuse... we also tried buying mini clamps from home depot and those didn't work either... there was either not enough room in the wheel well to clamp them or there wasn't enough room between them and the tire to install.... so we scratched that idea too...
What we ended up doing was hot gluing neodymium magnets to both the car and the frame and having the magnets attach to each other, making this skirt cage easily detachable, simple wrench off and snap back on... the attraction between two neodymium magnets was so powerful that it took us great effort to separate them from each other... there is no way I can hit a bump hard enough to get the magnets to fly off of each other.
Here are the pictures:
Wheel with cage on
Same wheel with cage, view from the back
Same wheel with cage, view from the front
Same wheel, view from the top:
Same wheel, closeup of how close the plastic bit gets to the wheel
Same wheel, closeup of how the joint in the cage is hotglued and ziptied together
Closeup of magnet glued to car
Closeup of magnet glued to top of wheel
closeup of magnet glued to cage
cage shown taken off of wheel
Other wheel (left wheel) view
Other wheel back view
Other wheel view from front
Other wheel angle view
Other wheel top down view
Other wheel angle 2
Other wheel angle 3
Back of car view
Much thanks to cfg83 for the help, tools, opinions, and manpower for doing this, we will be modding his car next.
Please please give us some feedback on this, how does it look? Did I go too low on the tire (since the car curves inwards from the top), thoughts? Opinions? Rants?
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 75 03-01-2012 07:28 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 06:03 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 06:44 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
