Old 09-06-2008, 07:28 PM   #11 (permalink)
Red Beast - '82 V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Neon SXT
90 day: 28.71 mpg (US)
I would not use a large sample pool. that was just a reasoning for not doing it. I did not realize that a 'last 1/2 second' solution was in the works. (too large a data set imo, and it seems to me that you would loose data intregrity for the mpg reading.)
I was merely showing an algorithm for screening out single anomylous readings. (Tossing out the signal would be bad, causing dropped counts for total miles.)
Using the min vss pulse for a time frame seems like it would show a little high for the speed if you have a glitch.
Old 09-06-2008, 07:30 PM   #12 (permalink)
of course, if we had a trace output of the anomalous pulses it would be easy to determine the easy way to screen them out.
Old 09-07-2008, 04:32 AM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Collecting data for a half second is entirely appropriate for display purposes, because that happens to be the display refresh rate. I have not suggested anything that would interfere with the accuracy of the trip accumulators, those are more important than the instant display. And yes, you need a "slop factor", as mentioned, my metro looks like 1.6.
re: traces, Here are a couple pulses (pm'd you the link):
VSS Signal assistance?
The problem comes in when you want to do something like an accurate coast down test to determine your cda/crr. cda/crr doesn't exist yet, but 1/2 a second resolution is less than ideal for that task, more than one pulse is also less than ideal too, the signal on the metro itself is far from ideal, there's only so much you can do with it.
The nice thing about the "slop theory" and tracking the min and/or max vss pulses per 1/2 second in the interrupt handler is that it is based on a physical limit of the existing system, i.e. the min or max should be mostly those readings where most/all the slop was at it's maximum extents, and thus we have a reference point, sort of
Old 09-07-2008, 04:15 PM   #14 (permalink)
The signal is very noisy on first look.
A little filtering would go a long way.
A simple circuit called a "Window Detector" will do this. Waiting for a specific value to turn on, and waiting for a lower value to turn off.
Old 09-07-2008, 04:17 PM   #15 (permalink)
Nasa guys huh?
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 04:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
Some suggestions and notes on the MPGuino SVOboy OpenGauge / MPGuino FE computer 4 08-01-2008 09:00 AM
Questions about mpguino mhmitszach OpenGauge / MPGuino FE computer 37 07-01-2008 08:38 AM
