Old 07-29-2008, 11:56 AM   #21 (permalink)
Lurking Around
Impulse's Avatar
96 Civic - '96 Civic CX
90 day: 35.61 mpg (US)
03 Corolla - '03 Corolla S
90 day: 30.35 mpg (US)
09 Sierra - '09 Sierra SLE
90 day: 19.76 mpg (US)
The most popular and cost effective way that I do for our customers is with a 12v spdt realy break open a starter wire and use a factory device (ie rear defrost button, push in cigarette lighter, install hidden switch etc) to imobilize the vehicle when it is not running. Now the key to doing this effectively, is to hide the relay out of sight under the dash, and making all your wire connections look stock, looming and running your wires with the factory wires. Now the reason for using a relay is because you dont want to use a switch directly to break open wires, (most of them melt, burn and short out) and a relay can handle 30/40 amps of current depending on what you get. If you or anyone has question on how to wire anything 12v to yuor vehicle, just pm me or let me know on here, as I am a certified MECP installer, and have been doing this for over 4 years
Old 07-31-2008, 03:46 PM   #22 (permalink)
Tupper - '97 SW2
90 day: 37.52 mpg (US)
yes, I wired a kill switch using my a/c button on my sw2. Since my ac doesn't work I figured out which pins were the switch and then just wired my injector power line through a relay, then powered the relay with the switch. Perfect stock look and easily accessible for great EOC. Definitely use a relay though.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Geo Metro Kill Switch Idea? HotRod EcoModding Central 5 01-27-2011 06:13 PM
DRL Kill Switch? gamer_jim EcoModding Central 8 06-05-2008 10:12 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
