Old 09-09-2010, 12:47 PM   #1 (permalink)
Help with Whistling Camper Van?
Hi all, kinda OT for this group but I'd like some help sorting out an annoying whistling noise on my camperized van. It seems to be coming from somewhere around the top of the windshield and mainly on the passenger side. I found a pretty good gap at the top of the windshield underneath the rubber gasket and filled that in with some foam amd that seemed to help a bit but it's still pretty bad on the highway. Any thoughts? I can get more photos if that will help. Apparently I can't post pics yet (need to get my post count up) but I'd be happy to send photos to anyone interested and will post back here when I'm able.
Thanks!
Greg
Old 09-09-2010, 12:54 PM   #2 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
It's not OT.
Wind noise = drag.
Can you maybe put them on a website, something like Flickr ?
Lifetime fuel consumption :
Old 09-09-2010, 01:46 PM   #3 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
Wind noise = drag
well yes and no, it's likely i small hole in a rubber gasket... carmakers spend a lot of time trying to eliminate noise...
the effect of these gaskets is quite clear when a window is just a fraction open or when a door is not fully closed, you imediately hear this.
my advice would be to try to track down the problem, find the damage and fix it... some sylicone might be a good way to fix it, but perhaps replacing the whole thing is also an option
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
The Following User Says Thank You to lunarhighway For This Useful Post:
aerohead (09-11-2010)
Old 09-10-2010, 07:22 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
Try one of the tricks my NVH friends used to use to find wind noise problems: Duct tape
Cover a suspected problem area with duct tape. When the noise changes, you know you are on something.
The Following 2 Users Say Thank You to CapriRacer For This Useful Post:
aerohead (09-11-2010), Phantom (09-10-2010)
Old 09-10-2010, 07:25 AM   #5 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
+1
Precisely
regards
Mech
Van rental question TheDon EcoModding Central 15 04-15-2011 02:35 PM
How to improve Dodge Ram Van from 12mpg? [Belly pans?] ahanix1989 Aerodynamics 47 02-06-2011 01:17 AM
Cab to camper shell gap... BamZipPow Aerodynamics 2 08-01-2010 08:18 AM
Confused! Which van has the best gas mileage? alohaspirit General Efficiency Discussion 9 02-25-2009 12:14 AM
Large GMC Van, possible improvements? Kalanco EcoModding Central 12 11-07-2008 10:12 PM
